Spark Pluggss
Old Oct 31, 2006 | 09:51 PM
Notpilbrisk's Avatar
Notpilbrisk
Question Spark Pluggss
I am attemoting to change my spark plugs on my 99 expedition XLT with 221000 on it. Any tips or advice before I dig in? ANY help would be greatly apriciated!!
Old Oct 31, 2006 | 10:16 PM
Mochajones's Avatar
Mochajones
https://www.ford-trucks.com/forums/1...ht=spark+plugs
Here is a link I was directed to. Hope it helps you as much as it has me.
Old Nov 1, 2006 | 11:26 AM
slc10844's Avatar
slc10844
I have two suggestions. Don't change the plugs on a hot engine. Change them on a cold engine if possible. Second, if the plugs are tight coming out don't force them. Spray some penetrating oil in the hole and work the plug in and out until it frees up.
Old Nov 1, 2006 | 11:29 AM
MisterCMK's Avatar
MisterCMK
Use plenty of extensions and swivels and some patience pills. Blow out the plug well with compressed air before you change the plugs. Also add some anti-sieze to the threads of the plug before you re-install them.
Old Nov 1, 2006 | 12:19 PM
Notpilbrisk
Do the 1999 expeditions have coil packs on the 4.6l engines?
Old Nov 1, 2006 | 04:12 PM
MisterCMK's Avatar
MisterCMK
I don't believe so.
Old Nov 3, 2006 | 09:56 AM
SemperFi's Avatar
SemperFi
How did the plug replacement go? I did mine and had some issues with extension or there lack of having enough extensions on hand-- luckily the neighbor leaves his garage open -- The remember the 7 "P's"
Proper Prior Planning Precludes **** Poor Performance
Old Nov 8, 2006 | 02:49 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Coil Packs
We show that your '99 Expedition does utilize coil packs.
Hope you will consider our Screamin' Demon Coil packs and Live Wires for your Expedition-see:
http://www.performancedistributors.com/f-150ignition.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
ymirr
Apr 6, 2017 07:42 PM
Boodrow379
Jul 10, 2013 09:41 PM
Ford Bronco Man
1978 - 1996 Big Bronco
15
Jun 3, 2011 11:19 AM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
mswift
23
Jul 19, 2006 09:42 PM
