bearing clearance
Old Oct 27, 2006 | 02:02 AM
airharley's Avatar
airharley
bearing clearance
What is the clearnace required on the main and rod bearings? I haven't been able to find it on google or using the forum search. I would like to start building my engine in the morning if at all possible. Thanks guys.
Old Oct 27, 2006 | 04:38 PM
bronco521's Avatar
bronco521
is it gonna be mostly street?if so between.002-.003 on the rods and mains is ok.if it's something you're gonna beat on look for the looser side.003
Old Oct 27, 2006 | 06:58 PM
monsterbaby's Avatar
monsterbaby
According to my book that I have handy mains are .0008-.0026, rods are .0008-.0025, I prefer to use more along the lines of .0020-.0025 on a street engine that you want to live (.0008 seems a lot too tight to me, min I would accept would be around .0018 if it was my motor but just quoting from the manual) On a race engine I run .0035 +/- .0003 and rods I run .0030-.0035
Old Oct 28, 2006 | 02:05 AM
airharley's Avatar
airharley
Using the plasti-guage kit that came with my bearings, I have a .0015 on the mains and .0015 on the rods as well. I checked it several times on different bearings to make sure too. Do you think having assembly lube on the bottom side of the crank is going to throw the reading off that much? I called a few machine shops in my area and they all agree that it isn't too tight with assembly lube in there as well. I am pretty amazed to find it this tight though. I put a TQ wrench on it to see what it takes to spin the crank alone and it is spinning at 4 Ft-Lbs. With all the rods and pistons I am pulling 24 Ft-Lbs. I also measured end play to be .005 which is almost in the middle if those shops are right. So far so good for the build up. I am waiting for some 8802 sealant to harden in the timing cover before I put it on.
Hopefully by the 15th of Nov I will have the engine installed in the truck to mock up the fuel lines. I've been in the garage a lot of the past month or so keeping my truck company rather then my wife. She informed me of this earlier today after I forgot to go to lunch with her.
Old Oct 28, 2006 | 09:55 AM
monsterbaby
You can't check the bearing clearence with assembly lube on the crank and expect it to be right .0015 is pretty tight until you take the assembly lube into context. But I don't think your rolling torque figures are too bad so I think you are all right.
Old Oct 28, 2006 | 01:09 PM
Paul Kane's Avatar
Paul Kane
Smile
Originally Posted by airharley
I have a .0015 on the mains and .0015 on the rods as well. I checked it several times on different bearings to make sure too. I am pretty amazed to find it this tight though. I also measured end play to be .005 which is almost in the middle if those shops are right.
You still haven't specificed the application of this engine, but for stock block motor / street driven bearing clearances you are fine. .0015" will provide plenty of lubrication, oil control and stable pressure all at the same time for a stock/mild street driven motor. Bearing clearances are not so critical in such a motor that one must be counting tenths.
If you have a very high performance engine, though, then you should dismiss this recommendation and post more specifics about your build.
Paul
Old Oct 29, 2006 | 02:58 AM
airharley's Avatar
airharley
The engine is for a daily driver with the occasional romp on the gas to put people in there place. No track use in the fore seeable future or hard driving for this engine.
got2bjoester
Escape & Escape Hybrid
26
Dec 24, 2015 03:13 PM
ItsAFord55
Nov 20, 2015 02:24 PM
scottddove
Aug 12, 2015 12:48 AM
joegeds
Oct 9, 2014 11:25 AM
Funke1
17
Sep 30, 2014 02:28 PM
