Sponsored by: Real Truck
OBD code P1633?????
Old Oct 22, 2006 | 12:03 PM
glmf 1's Avatar
glmf 1
OBD code P1633?????
Can anyone offer any insight on this code I am getting on my 02 5.4 SC F250. After searching I found a TSB about improperly installed fuses but that doesn't seem to be the issue here. I know the code is Keep Alive Memory Voltage Low. But the truck has 100k and now this show up. Could it be an alternator or battery thing? Thanks guys
Old Oct 22, 2006 | 08:21 PM
ReAX's Avatar
ReAX
A bad connection is my first thought. There is a big connector on the driverside firewall just below the brake booster. It takes a 10 mm socket to pull it, and a couple of 10mm and 8mm sockets to pull the pcm. I can't find my diagrams for 02 F250, but it couldn't hurt to hit both connectors with contact cleaner. While your at it, clean your battery terminals and look for the pcm ground wire and follow it the ground.
Old Oct 23, 2006 | 04:21 AM
glmf 1's Avatar
glmf 1
Thanks ReAX, one more question. The pcm ground wire,, does this originate at the battery??? The smaller wire right from the terminal? Thanks again for your help
Old Oct 23, 2006 | 05:58 PM
ReAX's Avatar
ReAX
No, it should be a chassis ground. Try to find a PCM pinout, I can't find the one I had.
kbf1961
Oct 17, 2015 10:05 PM
Samsn4
21
Aug 27, 2014 05:47 PM
Etteldorf
Jun 11, 2014 10:05 PM
BiltFordTuff
Jul 23, 2011 04:53 AM
The Phenom
1997 - 2003 F150
Jun 16, 2004 08:20 PM
