replacement water pump still leaking
Old Oct 20, 2006 | 07:29 PM
newkyford's Avatar
newkyford
1970 F100 302 water pump was leaking - replaced and now it's leaking around the bolt holes for the alternator bracket - all input welcome -- everything I fix on this truck seems to turn into 2 more problems
Old Oct 21, 2006 | 01:25 PM
Nod's Avatar
Nod
leak
newkyford,do the bolt holes in that area go into the water jacket in the block or intake manifold ?My 390 does that on the passenger side so I use thread sealer on the bolt threads and a flat washer instead of a split loc washer at the bolt head and I have never had a leak at that point.Also put a dab of silicon sealer on the flat washer both sides before you tighten.Hope this helps.PS, check first that you do not have a cracked or deformed water pump.
"bowties in the rearview mirror"
Old Oct 22, 2006 | 07:36 PM
newkyford's Avatar
newkyford
thanks for the help! I went back and found two of holes were plugged with silicone. I got that cleaned out, went to the farm supply store for bolts, dabbed on sealant and replaced it all. that was 36 hours ago - so far so good.
jte1998
Mar 23, 2021 07:38 AM
mneal1105
Dec 2, 2014 06:24 PM
Marauder2004
Jun 30, 2014 07:17 PM
Breezland
Jan 15, 2014 09:30 PM
Will_01_GT
1978 - 1996 Big Bronco
Aug 3, 2005 12:39 PM
