Water pump leak
Old Feb 6, 2017 | 05:36 PM
jte1998's Avatar
jte1998
Water pump leak
I've replaced my water pump on my truck three times and every time it seems like by the second week I have a leak but it won't leak until I cut the truck off that's the only time it leaks if it's running it won't leak at all
Old Feb 6, 2017 | 05:50 PM
FoxFord33's Avatar
FoxFord33
Are you absolutely positive it's the pump? Could it be the water neck/thermostat housing? I have also heard of one of the tiny bypass hoses having a pinhole leak spraying onto the pump body and making it look like the pump was leaking. But if it's truly the pump itself, maybe a bad brand? Three in a row happens sometimes these days...
Old Feb 6, 2017 | 06:22 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Where are you seeing the coolant? Is it coming out of the back of the water pump or the weep hole? Is it on top of the timing cover? Have you put a pressure tester on it?
Old Mar 22, 2021 | 06:47 PM
billybe4od's Avatar
billybe4od
leak
i changed my water pump last year an just recently i see a small drip coming off the block i kept watching an seen it leak from the back of the water pump against the timing chain cover, i re tighten all the pump bolts an 2 were loose well it stopped thank god
Old Mar 23, 2021 | 07:11 AM
torq'ta 5 8's Avatar
torq'ta 5 8
What engine?
Old Mar 23, 2021 | 07:38 AM
billybe4od's Avatar
billybe4od
Originally Posted by torq'ta 5 8
What engine?
sorry about that !!
5.8 97 f 250 hd
136,000. From Autozone
throwdown
23
Mar 12, 2009 08:28 AM
gofast51004
Mar 5, 2009 08:53 AM
crazer42
Nov 26, 2008 07:58 AM
Tofudi
Jun 4, 2007 07:28 AM
scotty
Jan 2, 2001 11:21 PM
