1978 - 1996 Big Bronco
Water pump gasket leaking?
Old Aug 3, 2005 | 09:47 AM
Will_01_GT's Avatar
Will_01_GT
Suggestions please, I have a coolant leak on the my 96 Bronco, 5.8 with 140k miles. The coolant is leaking around the crank shaft and down to the cross bars. I've tried Bars, replace the thremostat and gasket, the hose. I reflushed and tighted all the lower hoses. I checked the weep hole in the water pump, thats dry! Could the water pump gasket be leaking and I just can't see it or feel it. You have to rev the engine to get it to leak, a pump doesn't cause it. I'm stumped !
Old Aug 3, 2005 | 11:56 AM
94 XLT White/ Silver 302's Avatar
If it's not your water pump gasket it's probably the gasket between the timing chain cover and the block, that's where my leak was coming from. I would clean the front of the engine real good with some carb. cleaner then you may be able to see the leak.
Old Aug 3, 2005 | 12:29 PM
HMA-169's Avatar
HMA-169
I agree with 94XLT. Two out of the three small block fords I own leaked between the block and timing chain cover. The gaskets become hard and brittle over time. Look to see if you have any coolant puddles on the top/sides of the cover. You may try to re-torque the bolts for the cover and the lower intake while your at it. Otherwise, let the games begin. Not too bad of a job really.
Old Aug 3, 2005 | 12:39 PM
aurgathor's Avatar
aurgathor
I had a water pump gasket leak -- part of the gasket was caked onto the block, the other part was literally disintegrated. Cleaning the remnants of the old gasket off the block was a real PITA and took me a couple of hours. In the middle of the night....
dave1969
1983 - 2012 Ranger & B-Series
Nov 25, 2016 10:26 PM
wrenched
Apr 14, 2015 05:16 PM
ScaldedDog
Jan 17, 2015 07:30 PM
GormGorm
13
Dec 24, 2014 11:28 PM
JBronco
Mar 2, 2003 04:51 PM
