Exhaust system!
Old Oct 19, 2006 | 02:52 PM
Patbo8's Avatar
Patbo8
Exhaust system!
I just bought two flowmaster maufflers for dual exhaust can they easily be put on or is it not possible. I got a 2001 Ford Ranger Edge.
Old Oct 19, 2006 | 03:24 PM
Ranger4x4's Avatar
Ranger4x4
You will need dual pipes coming out to put both mufflers in. Also you will need to be able to cut the factory muffler out and weld. Also dont forget about hangers
Old Oct 19, 2006 | 03:25 PM
bigdavesohc's Avatar
bigdavesohc
My advice it to let an exhaust shop handle it. If you had one Flowmaster, it would be ok. But two would be too much trouble for someone inexperienced.
Old Oct 19, 2006 | 07:09 PM
Patbo8's Avatar
Patbo8
Smile thanks
yeah that was my plan but i just dont want to buy **** and have them say oh we cant do that sorry.
Old Oct 19, 2006 | 08:35 PM
Bob Jusnes's Avatar
Bob Jusnes
You should only need one muffler, and you would be best off to have a muffler shop do it, because you will probalby need some piping too, since the flowmaster is shorter than the OEM muffler
Old Oct 20, 2006 | 06:13 AM
wendell borror's Avatar
wendell borror
You can not run a true dual exhaust on our trucks, it's illegal, but you can Y it after the cat and have 2 mufflers, you can have dual exhaust that way, it's not a true dual exhaust , but close enough, or as close as we legaly can get. The only reason a shop wouldn't do it, is if you wanted them to remove the cat, rigging up duals after the cat would be no problem and any exhaust shop should do it. Your next question would be, "how much do you think it will cost". I would call around in your area for the best price, I'm thinking since you allready have the mufflers, it should be around 200.00$, but don't quote me on that, call around.
Old Oct 20, 2006 | 08:43 AM
alan hodges's Avatar
alan hodges
How would running true duals be illegal? I would think if you ran dual cats and a cross over you would get the same as a singal pipe. If you had headers with the o2 sensor in them with all the factory stuff I would think this would pass. I know to do this it is not cheap but this is why they have 50 state legal mods. I'm sure some states are differant, so you would want to check first.I know in Colorado there tuff ,but if you have the proper paper work you can do it.
Old Oct 20, 2006 | 11:23 AM
Bob Jusnes's Avatar
Bob Jusnes
it depends, some states, like california wont let you alter the stock configuration at all, which would mean you couldnt run true duals, since there are cats in the system after the Y pipe
Old Oct 20, 2006 | 01:42 PM
fordboy_52's Avatar
fordboy_52
my ranger actually has 2 cats on the down pipes, thats how i made it with the true duals. the only prob is one o2 sensor, and it goes out all the time
Matt
