96 ranger, code 1443 (vacuum sys.)
Old Oct 15, 2006 | 08:37 PM
mustang67n's Avatar
mustang67n
my brothers 96 ranger is throwing a code 1443. looking at the code list on here, that is the vacuum system- PCS or PCV valve.
when throwing this code, what is the most common problems causing it?
im trying to narrow down my search before i start buying stuff lol.
does this code just mean that the PCV valve needs raplacing?
thanks for everyone who ends up helping :-)
Old Oct 16, 2006 | 08:07 AM
pawpaw's Avatar
pawpaw
I read it as a problem with the fuel vapor recovery canister solenoid.
Old Oct 18, 2006 | 04:27 PM
mustang67n's Avatar
mustang67n
this is a direct copy paste from the OBDII diagnostic trouble codes page on this site...
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
which i think is the same as the fuel vapor recovery canister solenoid your talking about.
how do i fix it though?
what are the most common problems on these trucks when throwing this code.
Old Oct 18, 2006 | 06:07 PM
pawpaw's Avatar
pawpaw
Well you'd want to do some testing to see whats wrong.
With the vintage of your ride, vacuum hose condition & connection tightness would be on the check list. Dry rotted vacuum purge line was the problem on my 94 Taurus.
Test for battery power to the purge solenoid. It comes from the PCM power relay, when the ignition switch is turned to "run". See if the relay is working, when you apply power.
Using a vacuum pump, see if the purge control diaphragm will hold a vacuum for at least 20 seconds, if not replace it.
Let us know what you find.
Old Oct 20, 2006 | 05:45 PM
mustang67n's Avatar
mustang67n
thanks a lot! thats exactly the kind of answer i was lookin' for! :-)
i'll let y'all know!
LISTEN
Aerostar
Apr 17, 2017 01:36 PM
Hell_Fish
May 5, 2009 08:41 AM
stupid red ranger
Aug 11, 2004 03:58 PM
pill90
May 21, 2003 08:33 PM
timdco
Apr 11, 2003 11:53 PM
