Engine code?
Old Oct 1, 2003 | 12:52 PM
Hell_Fish's Avatar
Hell_Fish
Engine code?
The check engine light came on in my wifes 96 Ranger. Auto Zone pulled the code. It is P1443, can anyone help me figure out what it means?
Thanks.
Old Oct 1, 2003 | 03:00 PM
Rockledge's Avatar
Rockledge
P1443
EVAP Control System Canister Purge Valve (Mechanical) Malfunction
Monitors the fuel vapor flow between the engine intake manifold and the EVAP canister. The system failure occurs when a leak or blockage between the intake manifold, the EVAP canister purge valve and the EVAP canister is detected by the PCM.
Old Oct 1, 2003 | 06:06 PM
Ranger95's Avatar
Ranger95
Change the valve and Sensor - about $75 Dealer only part, I just replaced mine on my 95 Ranger V6 - No more codes after that
Old Oct 2, 2003 | 10:26 AM
Plastic's Avatar
Plastic
Is it a 2.3L? I just ordered part F57Z-9C987-AB online, which is Canister Purge Solenoid/Flow Sensor Assembly for a 2.3L, so it has both parts. Found that info on this thread.
Old Oct 2, 2003 | 11:09 AM
Hell_Fish's Avatar
Hell_Fish
Thanks.
Old Oct 6, 2003 | 12:26 PM
Hell_Fish's Avatar
Hell_Fish
It was the valve and sensor. It cost about $95. The hoses were cracking pretty bad. Hooked it up, and unplugged the battery. Gave it back power and no more check engine light. Thanks.
Old Jun 26, 2004 | 03:31 PM
vieris's Avatar
vieris
ordering part F57Z-9C987-AB
in reply to this post .
"Is it a 2.3L? I just ordered part F57Z-9C987-AB online, which is Canister Purge Solenoid/Flow Sensor Assembly for a 2.3L, so it has both parts. Found that info on this thread."
anyone know what site has this part?
Old Jun 28, 2004 | 09:33 AM
Hell_Fish's Avatar
Hell_Fish
Thats the Ford part number. You can get it at any dealership.
Old Jul 9, 2004 | 06:34 PM
vieris's Avatar
vieris
cycle?
ok i intalled a new f57z 9c987 ab... should the light go off right away? or will it have to cycle.. i've heard something like it might need to have 11 engine cycles before the computers resets? what happend with yours?
Old Jul 9, 2004 | 09:47 PM
Ken00's Avatar
Ken00
If you disconnected the battery to reset things you should pull the codes again, there's another problem.
Old Jul 12, 2004 | 08:13 AM
Hell_Fish's Avatar
Hell_Fish
I disconnected the battery then turned on the headlights, to spend and built up charge still in the system. Then hook back up the battery and no more light.
Old May 5, 2009 | 08:41 AM
jtvcreatv's Avatar
jtvcreatv
Same thing is happening to me. The dealer here in Raleigh wants $170 for the Canister Purge Solenoid/Flow Sensor Assenbly. WOW!. Last year I had the same problem and solved it by cleaning the Sensor w/ WD-40. Now I'm having the same P1443 code so I pulled out the entire assembly because I damaged the Sensor pin where it connects to the hose. I think I can fix the damage but before I go through the trouble is there any way to tell if the Purge Solenoid is faulty. I tried to blow air though it but could not. Oh. And smelling gas in the engine compartment.
famf23
Feb 26, 2005 06:32 PM
czabala
Computer Chips & Tuners
Sep 14, 2004 01:18 PM
May 3, 2002 01:31 AM
PaulH
Oct 4, 2001 01:55 PM
flatbranch
1997 - 2003 F150
Jun 2, 2001 10:55 AM
