Programming a WIRELESS KEYPAD for KEYLESS ENTRY
Old Oct 12, 2006 | 06:25 PM
MattsExcursion's Avatar
MattsExcursion
I was wondering if anyone knew how to program a wireless Keypad (magnetic ad on from Ford)
I have been searching online for a long time, and I can't seem to figure it out!
Thanks in advance!
-Matt
Old Oct 13, 2006 | 11:25 AM
ramsmoker's Avatar
ramsmoker
Talking Key pad
If you have your manual, the instructions are in there. Also in the little black book on the inside of the front cover is the default code. You must have the default code to start the process. Your friendly Ford stealer can furnish from your VIN number. You can PM me if you like and I can scan and email you the page from mine.
Old Oct 13, 2006 | 08:04 PM
MattsExcursion
We don't have the manual and its a Ford Part, but purchased after the vehicle... Can they still look up the code?
Old Oct 15, 2006 | 08:18 PM
BowTieHatr's Avatar
BowTieHatr
you dont need the factory key code. if it is the aftermarket ford accesory, it should have a code card in the box. switch the key on and of 5 or 8 times and end in the on posistion. the locks should cycle if working properly. press the lock buttons on each remote you have and then punch in the code from the keypad. just remember, they work like a fob not like keyless entry. they lock and unlock your doors with the vehicle off not running.
Old Oct 16, 2006 | 07:45 AM
MattsExcursion
you mean a code card in the box it came with? because the after market for keypad keypad was installed by a previous owner
Old Oct 16, 2006 | 11:32 AM
BowTieHatr's Avatar
BowTieHatr
you might be outta luck then unless you can contact the preveious owner. you wontbe able to pull a code. by the way these are stick on not magnets
Old Oct 16, 2006 | 07:51 PM
MattsExcursion
i just figerued that out when trying to remove one lol
simplywebb
2004 - 2008 F150
Mar 18, 2014 06:02 PM
speedyvuu
23
Mar 16, 2010 04:59 PM
andrewlcraft
Mar 12, 2010 06:52 AM
stuart1031
2004 - 2008 F150
Feb 21, 2010 08:26 PM
jerryb228
Jul 22, 2007 03:47 PM
