Sponsored by: Real Truck
Replacement Steering stabilizers
Old Oct 10, 2006 | 11:13 PM
jake00's Avatar
jake00
ummm... Stupid Q.... I dont think my truck has one of these, Should it?
Old Oct 11, 2006 | 11:03 AM
EnviroCon's Avatar
EnviroCon
It may not have come stock with one, but given the size tire you just put on there I would seriously consider getting one (or two).
Old Oct 11, 2006 | 11:49 AM
Rollin03F250's Avatar
Rollin03F250
does anyone know if a dual will work with this adjuster thing? Sorry dont know the name but heres a pic.
Lonewolftx's Avatar
Lonewolftx
Arrow Sure you do . . .
If it is a 4x4 then there is one on thr front axel somewhere. Climb under there and look for a small type shock going crosswise with the axel.
Old Oct 11, 2006 | 02:05 PM
RACERX7775's Avatar
RACERX7775
ok, i am seeing the stabalizer on alot of trucks here. they are all on the left side of the truck. mine is on the right side. and its all stock. does that seem right?? its an 01.
Old Oct 11, 2006 | 05:03 PM
jake00's Avatar
jake00
I just put a lift on and didnt see one, but wasnt looking for it either, I'll check again
Old Oct 11, 2006 | 08:13 PM
jake00's Avatar
jake00
my axle looks just loke the one in the pic above i dont have one????
Old Oct 11, 2006 | 09:57 PM
cc322's Avatar
cc322
Old Oct 11, 2006 | 10:03 PM
RACERX7775's Avatar
RACERX7775
cc322, how does that thing do? can you feel a difference? was it worth it?
Old Oct 11, 2006 | 10:25 PM
cc322's Avatar
cc322
Ok I have to be honest, when I had it put on I thought I liked it, then after many long drives five hours or so, I have taken it off. It was installed in March and was taken off this past Monday. I had some front steering issues and the dealer replaced tie rod end to pitman arm, panrod bar bushings and put the factory steering damper on, and it is 100% better like new again. Fox calls this a direct replacement and it is not, the Fox damper is a nitrogen gas filled system, with a 50/50 valving, but there is always positive preassure towards the left side kinda always counter steering. I called Fox and was told I could lower the preassure but never did. If I ever get another aftermarket kit I will go witht the Donahoe kit. Hope this helps. BTW Donahoe has great customer service.
http://www.donahoeracing.com/cust_ga...p?galleryID=59
Old Oct 12, 2006 | 01:52 PM
Munkey's Avatar
Munkey
Here's my offering...
Fabtech 'direct replacement' stabilizer. Cost me around $40 from truckperformance.com
Honestly...I didn't notice a difference between the old dented leaking stock stabilizer, and the new Fabtech unit.
Paint chipped off and rusted the shock body...some sanding and flat black Rustoleum took care of that.
Old Oct 12, 2006 | 08:51 PM
jake00's Avatar
jake00
Why dont I have a stock damper? Was it an option?
Old Oct 12, 2006 | 09:05 PM
  #28
EnviroCon's Avatar
EnviroCon
I don't believe the steering damper was an option itself. And it didn't come standard with all 4x4's. It was a part of some packages like the FX4, snow plow, Heavy Service Suspension, and there may have been others. So I guess the short answer is your truck didn't come with one of those packages.
TC-Countryboy
Sep 20, 2017 09:52 PM
Rick Cargo
6.7L Power Stroke Diesel
55
Aug 22, 2012 05:41 PM
bluerock5
Apr 20, 2011 09:02 PM
mdwilli
Apr 21, 2009 10:25 PM
khmorse
Mar 9, 2004 07:41 AM
