steering stabilizer
Old Mar 6, 2004 | 10:05 AM
khmorse's Avatar
khmorse
steering stabilizer
http://www.central4wd.com/store/itemdetail.asp?ID=8629
Has anyone added a steering stabilizer to an Expedition? I see they sell them for the 2001 Expedition, but I don't have a stock steering stabilizer. If someone has added one, did it help? Was it hard? What else needed changing besides the stabilzer?
Thanks,
Old Mar 6, 2004 | 10:08 AM
prcrboy's Avatar
prcrboy
Ken,
I have added them to f150 but not my expy. Do you run oversized tires? Why were you thinking about adding one?
The principle is simple, it acts like a shock absorber for the steering, and is a MUST with oversized tires.
Old Mar 6, 2004 | 10:17 AM
khmorse's Avatar
khmorse
No, I am not running oversized tires. But I do tow a camper quite a bit and thought it might help w/that also.
Old Mar 6, 2004 | 05:47 PM
tsdrallyer's Avatar
tsdrallyer
Steering stabs are to minimize jerks in the steering wheel (unfortunately doesn't eliminate jerks behind the wheel :-) ) caused by over sized tires causing bump steer, or by hitting rocks or sudden deep holes when off road (or some northern streets).
With the 17" wheels on my Expy I've never felt the need for one.
I can't see at all where a steeering stab would help in a towing situation on normal roads. I tow off the pavement and off the road frequently and have never had a steering jerk problem due to being observant for obstacles,and reasonable speed for the conditoins.
Old Mar 6, 2004 | 07:20 PM
myblkexpy's Avatar
myblkexpy
I have steering stabilizers on both the Bronco and the Pathfinder. As mentioned above the stab helps when you hit a hole or a bump. The expy has never had wheel jerk that would make me want to add one. It wouldn't help a bit with towing.
Old Mar 8, 2004 | 12:06 PM
buzzard's Avatar
buzzard
I've got one on my '00 4x4 and think it's the best $50 ever spent. I do have 33" tires (+3" over stock), however, it helped steering feel tremendously even without the larger tires.
Old Mar 8, 2004 | 06:49 PM
khmorse's Avatar
khmorse
Thanks all.
Old Mar 8, 2004 | 08:28 PM
allanhilliard's Avatar
allanhilliard
I added one and can honestly say that I don't feel any difference. This doesn't mean that it's not helping, just that I don't feel it if it is.
Old Mar 9, 2004 | 07:41 AM
Voksboy's Avatar
Voksboy
I added one around 3 months ago. I do run 33x11.5x17 and they worked great. For around $50 they are well worth it and easy to install
DL222
Jul 3, 2017 12:10 AM
paintubturner
Jun 23, 2017 10:14 PM
kbsupercrew
1997 - 2003 F150
May 13, 2012 10:00 AM
brwolfjr
Mar 17, 2006 08:40 AM
