Hub Bearing
Old Oct 9, 2006 | 02:59 PM
cdiddy's Avatar
cdiddy
Hub Bearing
Does any one know the ford part # for the auto hub bearing for an 02 4x4?
Old Oct 9, 2006 | 03:05 PM
MAKO314's Avatar
MAKO314
the front wheel bearing and the hub are all one piece I'm not sure of the part# but I do know you will not like the price especially if it has front abs. hope this helps
Old Oct 9, 2006 | 03:21 PM
Pocket's Avatar
Pocket
Yeah I just had mine replaced on the driver's side front. $380 for the assembly. I don't know the part number, however you can get it from Ford. Look on the back side of the front axle, there's a sticker with a yellow stripe on it (should be on the axle housing near the pumpkin), your dealer needs the number off that. Apparently there are several different ones for 2002, so your dealer needs that number to locate the right one.
Old Oct 9, 2006 | 03:41 PM
MAKO314's Avatar
MAKO314
napa has the hub assem for non front abs trucks and its much cheaper
Old Oct 9, 2006 | 04:55 PM
bhiggins's Avatar
bhiggins
rebuilt hub assembly
can the hub assembly be rebuilt? you could the old ones
I'm haveing the same problem currently i just prices a new one at advanced auto for 265 and i thought that was outragous
Old Oct 9, 2006 | 05:12 PM
Pocket's Avatar
Pocket
Nope
Old Oct 9, 2006 | 07:52 PM
bhiggins's Avatar
bhiggins
you mean to tell me as many mechanics are on this site NONE of you have tried taking the bearings out and finding the replacements?
what is so different about this bearing as opposed to the older ford wheel bearings. I know you could change just the bearing on the older ones
Old Oct 9, 2006 | 07:56 PM
MAKO314's Avatar
MAKO314
the new style hub is sealed and suposedly greased at the factory. I did try to get it apart, it took a machine shops press and time it came apart I had to buy a new one anyway. someone needs to figure out a way to drill and tap for a grease fitting.
Old Oct 9, 2006 | 08:46 PM
jtharvey's Avatar
jtharvey
It depends on which bearing. There are two in the hub. One is a sealed bearing, and it cannot be replaced or serviced without replacing the whole hub. The other is a typical needle bearing, and it is servicable. I've recently replaced my needle bearings, and others have serviced theirs. Guzzle has a nice writeup on servicing those bearings. Click here: http://guzzle.rbmicro.com/nblube.html
While you're at it, you may service your front hubs if they're auto lockers. Click here: http://guzzle.rbmicro.com/allube.html
Old Oct 9, 2006 | 10:42 PM
KrenzyRyan's Avatar
KrenzyRyan
My hub went out, and here is my new one:
Old Oct 10, 2006 | 08:44 PM
bhiggins's Avatar
bhiggins
anybody ever ordered from this guy
idea's thoughts suggestions????????
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Old Oct 10, 2006 | 10:40 PM
KrenzyRyan's Avatar
KrenzyRyan
[QUOTE=bhiggins]idea's thoughts suggestions????????
http://cgi.ebay.com/ebaymotors/Ford-F250-F350-Front-Wheel-Hub-Bearing-Assembly-New_W0QQcmdZViewItemQQcategoryZ46104QQihZ017QQitem Z270037912519QQrdZ1QQsspagenameZWDVW[/QUOTE]
Well with no picture, I dont know if I would trust that haha. I like the Napa one because it comes with a lifetime warranty, plus, its quality... And cheaper than the dealer.
Old Oct 10, 2006 | 11:03 PM
cdiddy's Avatar
cdiddy
The hub from e-bay is non ABS and of course I need ABS. If you dont mind me asking how much did you pay at NAPA? I had ordered all of the parts from ford to service the needle bearings and rebuild the locking hubs before I found out I needed new hubs so I hope I can return the parts for the hub to ford because the new hubs come with all new parts right? Does anyone know the ford part # for the locking hub bearing?
Edit- I just found one on his e-bay sore that is 4x4 with 4 wheel ABS for $250. Is this a deal or what. I would rather have one with a life time warranty and good quality like the one from NAPA but since I need 2 of them, $250 is better than $400.
Old Oct 11, 2006 | 06:48 AM
bhiggins's Avatar
bhiggins
i'm of the opinion at this point that i can by 2 cheaper than i can by one napa. If it runs another 50-100,000 and i have to do it again well i'm still coming out cheaper. by 300,000 i'm going to have more worries than a new hub
HIggins
Old Oct 11, 2006 | 07:06 AM
BlueOvalBoy's Avatar
BlueOvalBoy
Napa has the abs version. Integral wheel bearing they call it.
Sometimes referred to as "the ones for 300 bucks" or "Ooh". A pain in the rear I call it.
Remember to go to ford to get the seals and studs. It will save you time.
Peace
centsless
May 17, 2024 07:59 AM
mrblonde108
Oct 2, 2010 10:47 AM
N3mo
2004 - 2008 F150
Feb 1, 2009 04:32 PM
Tennesseeduck
1997 - 2003 F150
Sep 18, 2007 11:50 AM
digger190
Jun 10, 2006 01:49 PM
