Old Oct 9, 2006 | 11:03 PM
fordlovin's Avatar
fordlovin
04/01
My sticker in the door says my truck was made 04/01. Does it not have the better rods?
Old Oct 9, 2006 | 11:06 PM
John311t's Avatar
John311t
IIRC You have the PMR's. I did think that i read somewhere about some 01's having Forged but i think that 04/01 is pure PMR.
Old Oct 9, 2006 | 11:07 PM
fordlovin's Avatar
fordlovin
what kind of power can those hold?
Old Oct 10, 2006 | 05:17 PM
fordlovin's Avatar
fordlovin
can any one tell me what a safe power level would be for me engine? or give a link?
Old Oct 10, 2006 | 05:55 PM
Cuda_jim's Avatar
Cuda_jim
Another PSD site says 350 HP is about the limit but they were referring to a gut pushing 400 w/PMR's
IIRC 10-00 was the cut off date, but there are a few afterwards that came with forged.
http://www.dieselinnovations.com/gallery2/v/tech/
Try this link, lots of picts.
There is a way to check your rods without taking the engine apart. There is a plug (1/2 NPT IIRC) near the oil filter in the block. If you remove it you can see one of the rods, but you gotta know what your looking for. The site above has many picts to help you.
Old Oct 10, 2006 | 06:11 PM
Uzumati's Avatar
Uzumati
It is said that the PMR's will grenade at 400RWHP so 350 is a good number to keep under.
Someone posted a while back the engiine serial number that broke the line between Forged and PMR's but I'll be danged if I can find it now
Found it: When you search it helps to be able to spell "Engne" correctly
https://www.ford-trucks.com/forums/4...+Serial+Number
I got forged Yahoo........
Old Oct 10, 2006 | 10:41 PM
fordlovin's Avatar
fordlovin
If the sticker on the engine says it has 250hp. Is that at the crank or wheels? In other words, if I got Jody's 120hp tune would I be safe?
Old Oct 10, 2006 | 10:48 PM
John311t's Avatar
John311t
That is what the engine will put it out. That is not at the wheels but at the crank.
Old Oct 10, 2006 | 10:52 PM
fordlovin's Avatar
fordlovin
Thanks for all the good info. By the way. About how much torque will be made at 350-375rwhp? Just curious.
Old Oct 11, 2006 | 07:43 AM
cangim's Avatar
cangim
General rule of thumb, the 7.3 almost doubles torque for HP, so if you truley make 350 the the rear, you'd be pushing 700ftlbs
Old Oct 11, 2006 | 08:34 AM
fordlovin's Avatar
fordlovin
Thnaks. I think that would probably be enough for me.
