Rear Diff fluid
Old Oct 8, 2006 | 02:18 PM
Uzumati's Avatar
Uzumati
75 is the "cold weather" rating so on that end they are the same
"At cold temperatures, the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up, the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C, the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot"
From Here: http://auto.howstuffworks.com/question164.htm
diesel7.3power
Aug 31, 2011 06:59 PM
01raptor
Jul 1, 2011 09:19 AM
brian931
1983 - 2012 Ranger & B-Series
Apr 8, 2009 07:16 AM
Rich in CO
1997 - 2003 F150
Nov 13, 2006 07:24 PM
dansV10
Nov 16, 2005 12:49 AM
