Diff fluid
Old Apr 7, 2009 | 08:07 PM
brian931's Avatar
brian931
Diff fluid
So I was thinking of changing the fluid in my limited slip rear axle this weekend and was wondering what fluid to use? Do I need the limited slip additive or can I get lube that already is set up for these diffs?
Thanks
Old Apr 8, 2009 | 05:30 AM
wendell borror's Avatar
wendell borror
Yeah, the clutch type lsd's need a modifier added. I don't know if there's any gear lubs that have the modifier allready in them or not, I dout it.
Old Apr 8, 2009 | 07:16 AM
pawpaw's Avatar
pawpaw
Don't know what year your ride is, but newer rides come from the factory with lubed for life synthetic differential fluid & friction modifier, that Ford says needn't be changed, unless the differential has been opened up & worked on.
All that said, if your still of mind to change it, be sure to use a synthetic gear lube that says on the container that it meets Fords specifications & add the specified 4oz of friction modifier.
Some gear lubes say they already contain friction modifier, but who knows how much????
Opt for the Motorcraft synthetic gear lube, with the specified 4oz of friction modifier & know for sure you have the right recipe.
diesel7.3power
Aug 31, 2011 06:59 PM
RhinoScores
Jul 5, 2009 06:52 PM
electrk
Jan 22, 2007 02:21 PM
brian931
Sep 27, 2006 10:22 AM
fors43
1978 - 1996 Big Bronco
18
Jan 12, 2003 02:11 AM
