Sponsored by: Real Truck
How do you replace leaf spring bushings???
Old Oct 5, 2006 | 09:30 AM
Super Steve's Avatar
Super Steve
I bought new spring bushings for the rear of my front springs because they were shot.
It took hours with air chisels etc. to get it out.
How do I put the new ones in?
The spring eye ID is about 1.359 while the bushing OD is 1.375, making it a VERY tight press.
I'm thinking the only way is taking the springs off and using a hydraulic press?
Anyone else have to do this yet?
steve
Old Oct 5, 2006 | 09:45 AM
Sport45's Avatar
Sport45
Did you try putting the bushing in the freezer for a bit to see how much it will shrink? A few minutes with a heat gun might expand the spring eye as well.
Old Oct 5, 2006 | 10:07 AM
donjamer's Avatar
donjamer
steve
We just fought with a set on my sons 79 F350.
What I learned is if you can't stand a little aggravation pay some one else to install them.
What finally work for us was to use bearing grease and smooth out the inside of the spring with a die grinder. I am sure you roughed it up taking the old one out.
We damaged the first bushing and 2 hydraulic jacks trying to get them in.
It went in real easy using the grease and a 5/8" threaded rod.
We used the rod with nuts and washers on both ends to tighten and pull in the bushing. Worked great until the last 1/2"..
The problem is the bushings inner sleeve is slightly longer than the outer. To get the rest of the bushing in we used a 1 1/2" socket as a spacer to allow the bushing to slide in.
Hope this helps...
Old Oct 5, 2006 | 06:06 PM
Super Steve
Donjamer, thats one thing I was thinking of last night, except with a u-bolt that I had laying around. A u-bolt just fits in the bushing but I would have to do something to the u to make it work. But I didn't think it would be able to pull the bushing in considering how hard it was to get the old one out.
steve
Old Oct 5, 2006 | 08:23 PM
donjamer's Avatar
donjamer
steve
The Threaded rod with washers and nuts worked great as long as you clean out the inside with a die grinder or sand paper then smear with grease..
Grease is the key...
Our first attempts without grease cause a broken 4 ton and 8 ton hydraulic jack.
With the grease we did not need a jack..
It was not very expensive to get the rod nuts and washers....
Good luck...
Old Oct 5, 2006 | 08:50 PM
EnviroCon's Avatar
EnviroCon
Are you guys replacing your bushings with stock rubber ones or polyurethane?
Old Oct 5, 2006 | 09:50 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's usually easier to remove the spring, and bring it to an auto shop with a press.
Even at $100/hr, it's worth the $50 to get them pressed in. (1/2 an hour max).
Then you need new u-bolts
Old Oct 5, 2006 | 10:02 PM
donjamer's Avatar
donjamer
We used stock replacements and they were hard to find for a 79 1 ton..
Old Oct 5, 2006 | 10:11 PM
donjamer's Avatar
donjamer
It may be easier, but you take all the fun out of it....
Cost of the bushings was $30.00 for 2... Then a little time to install
Cost to pull the springs would be
Bushings $60.00 for 4.. (If you have them out may as well replace both ends)
Labor $50.00 as stated. Maybe more...
4 U bolts about $15.00 each totalling $60.00...
So total to have them pressed in would be $170.00
That is why we opted to just manually install the 2 bushings on the truck..
Spent $30.00 versus $170.00
Old Oct 6, 2006 | 09:13 AM
Super Steve
I got the driver side in last night. Lubed it up with anti-seize and pulled it in with 1/2 inch bolts. Thanks for the tip donjamer.
Now if only I could find where I put the passenger side bushing so I can replace that one too.
I used bushings from superlift since I have superlift springs. Rubber inner, 1.375 OD, I don't know if they are the same as stock or not.
steve
steve340
19
May 5, 2017 10:36 AM
Steves55
Mar 17, 2015 12:28 AM
Jklnhyd
17
Jun 21, 2014 12:19 AM
lsrx101
Dec 2, 2008 01:43 PM
Trevor1
Oct 13, 2006 06:59 PM
