Bushing Removal Tool
Old Mar 16, 2015 | 02:05 PM
Steves55's Avatar
Steves55
Although I bought new pins and bushings for the front springs on my 55, I did not get the Bushing Removal Tool that Mid Fifty sells. Has anyone used it and is it worth getting? How is it used? This will the first time I have ever done this swap out and want to be as prepared as possible. Thanks.
Old Mar 16, 2015 | 02:32 PM
jimcar-9's Avatar
jimcar-9
Its a steel rod that has the dimension of the inner and outer diameter of the bushing. Any steel rod that has the correct diameter can be used.
DinnerHill SpeedShop: Rear main leaf spring bushing replacement
A press is recomended as you will damage the ends of the bushing if you hit it with a hammer or similar.
Either was you still need to ream them out when pressed into place
DinnerHill SpeedShop: Reaming new rear spring eye bushings
Old Mar 16, 2015 | 08:17 PM
DocRoche's Avatar
DocRoche
Ive heard of people burning themout with a blow torch. Smells, but simple. I had a buddy buy a press and it worked on my 64 F100. But as we were using it he mentioned how a torch would be easier. Ive never seen it used but could see how it would work.
Old Mar 17, 2015 | 12:28 AM
jimcar-9's Avatar
jimcar-9
Hi
Aren´t that only for rubber/steel bushed spring eyes ?
JBravo
Jan 10, 2010 02:53 PM
rcav8or
Jul 3, 2008 11:45 AM
4drf350
Oct 19, 2006 09:35 AM
jaydgraff
Sep 8, 2006 09:54 PM
