Heater problem
Old Oct 5, 2006 | 07:58 PM
  #31
Agemenon's Avatar
Agemenon
hmph, I'll keep that in mind
Old Oct 5, 2006 | 11:23 PM
  #32
dwaymar's Avatar
dwaymar
sometimes you might have to get to the heater core they will suck anything and everything down there so could be that it is stopped up also these fans are not the best on these old beast
Old Oct 6, 2006 | 04:29 PM
  #33
Agemenon's Avatar
Agemenon
Well my fan works awesome, it blows perfectly. Its just that it was about +5 outside the night I bought it, and it was about a 10 minute drive home...and not alot of heat was coming out, maybe I'm just because paranoid. I'll bring it on the highway to get a sense of where the heater core is at.
Old Oct 6, 2006 | 06:36 PM
  #34
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If it is 5 degrees F. outside then it will take several miles to get warm. When it gets that cold I put a piece of cardbord over 1/2 of the radiator and watch the temp gauge.
Old Oct 6, 2006 | 09:22 PM
  #35
Dave Sponaugle's Avatar
Dave Sponaugle
10 minutes is not enough time for the engine to get warm unless you are really working it.
Working it that hard in the first 10 minutes of running at 5 degrees would not be a good idea either though.
Old Oct 7, 2006 | 07:37 PM
  #36
Agemenon's Avatar
Agemenon
Ok I tested it out properly, I got sufficient heat coming out of the vents. Seems like the heater core works great after all.
blueeyedfordguy
Garage & Workshop
27
Feb 17, 2014 11:23 PM
73 ford guy
78
Oct 14, 2013 12:17 AM
Esslinger07
Dec 7, 2012 11:04 AM
bighighboy77
Dec 23, 2007 02:17 PM
Boss50
34
Feb 9, 2005 01:18 PM
