2001 ranger torque converter
Old Oct 4, 2006 | 01:36 PM
jr-bryant's Avatar
jr-bryant
Hi,
My 2001 ranger v6 has an automatic trans. the torque converter seems a little noisy when I stop or start in the first gear. One mechanic said this is quite normal for this model. Anyone have any other ideas? I only have 33,000 miles on the odometer and I just got the truck last month.
tks
jb
Old Oct 4, 2006 | 11:29 PM
Rockledge's Avatar
Rockledge
What kind of noise are you hearing? Describe it the best you can.
Old Oct 4, 2006 | 11:37 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I worked on a ranger A/T once 2002 i believe... had a clunk type noise when starting from a complete stop and stopping completely... also you could almost feel like a "hopping" sensation at the same time. Ended up being the transmission mount.
Although I could see nothing physically wrong with the original mount, the replacement was much thicker and compressed quite a bit on installation... It was a 'last ditch effort' to resolve the problem and it fixed it!
Just something to keep in mind.
Old Oct 5, 2006 | 08:15 AM
Joelski's Avatar
Joelski
Mine has that kind of turbo-sounding/hydroelectric generator sound revving up and down when you drive real easy. I guess that's how GM named their auto trannies.
Old Oct 5, 2006 | 02:04 PM
jr-bryant's Avatar
jr-bryant
Thanks, this is a great tip seeing how I have an apt. to get the transmission serviced on Monday, I'll ask them about that. My truck seems to have that clunk when stopping and starting, but when it's colder, it's not so prevalent.
jb
Old Oct 5, 2006 | 02:08 PM
jr-bryant's Avatar
jr-bryant
Mazda Ranger guy described it quite well as a clunk when you come to a complete stop or start from a stop. Sort of like the torque converter is jammed up into gear when you start from a stop or slips back out when you stop again.
tks
jb
Old Oct 5, 2006 | 02:43 PM
lllateralus's Avatar
lllateralus
Toyota 4Runners are notorious for doing something that sounds exactly like this.
(1996-2002)
What it is, is a driveshaft yoke/u-joint is basically binding, or gets almoast locked and then jerks when you let off the break. Sometimes they also do it when coming to a stop. Almoast feels like someone rear ended you slightly when it does it.
I *think* that the solution is to lube the driveshaft u-joints if I remember correctly.
You might want to look into this, as the t-conv. doesnt really go "into gear" or "out of gear". Its job is to flow torque through it smoothly, to absorb the impact the tranny makes while shifting, and to allow the engine to idle/spin while the tranny does not.
Look into the driveshaft yokes as a possibility.
Old Oct 5, 2006 | 07:39 PM
jr-bryant's Avatar
jr-bryant
(1996-2002)
This sounds interesting and seems like an easy fix, but Aren't some of the newer U joints permanetly sealed so you can't lube them?
Old Oct 5, 2006 | 08:19 PM
Joelski's Avatar
Joelski
Ya lube the yoke where it slips onto the tailshaft. That's where the thump comes from.
Has anybody experienced the cessation of this by cranking the torsion bars to level the truck? It seems to make sense that flattening the stance of the truck would fix that and maybe the ball joint problems...
Rick2001
Jun 1, 2010 06:38 PM
FrankZap
Aug 22, 2009 06:20 AM
robjs111
Jun 11, 2007 12:29 AM
Woodee1
Nov 2, 2006 12:45 PM
KennyG228
Feb 16, 2004 11:06 PM
