clunking noise
Old Sep 29, 2006 | 08:50 AM
turkeyman's Avatar
turkeyman
Exclamation clunking noise
There is a kinda clunking noise coming from the right front of my 00 4X4.
It doesn't do it until driven for a bit- have greased all joints- but still have it. seems to do it when hitting very light bumps-looking for ideas
Old Sep 29, 2006 | 09:34 AM
Beechnut's Avatar
Beechnut
Sounds very similar to my 02 4X4. It would do it for me after warming up and mainly when I hit a bump or applied the brakes.......I found out it was the ball joints.......replaced both sides upper and lower. Raise your tire off the ground and grab the top and bottom.....if you can move it then you know it is the ball joint.........good luck.
Old Sep 29, 2006 | 09:51 AM
turkeyman's Avatar
turkeyman
Thanks for the info-- thought the same thing but was told they were just replaced- did you do yourself- how difficult?
Old Sep 29, 2006 | 10:04 AM
Beechnut's Avatar
Beechnut
Did not do it myself after getting much input on that. It is a real pain. I bought the parts at cost through a buddy then had a reputable place put them in..........the mechanic who specializes in Ford front ends even told me to be thankful I did not try myself because it is a pain the ***. Some may say try it, but I didn't. Anyway, I ended up paying 500 bucks for everything and they turned my rotors and replaced pads also.
Old Sep 29, 2006 | 10:06 AM
Beechnut's Avatar
Beechnut
By the way, it started on my right front as well. Sounds exactly like mine. I ended up replacing both just for the heck of it but the left was not really bad.
MDSuperDuty
Dec 5, 2011 07:37 AM
flyer7.3
May 17, 2011 01:22 PM
Cool1996
May 25, 2004 07:39 PM
armyman
Feb 29, 2004 11:37 PM
d4small
Jul 25, 2003 06:40 PM
