Sponsored by: Real Truck
Clunk clunk noise
Old May 17, 2011 | 02:48 AM
flyer7.3's Avatar
flyer7.3
Clunk clunk noise
I have an 03 F250 7.3 with 80000 kms on it, when I do a full lock turn I get a clunk clunk clunk noise from the front end, any ideas what this might be.
Thanks
Baz.
Old May 17, 2011 | 08:52 AM
WestCoastTodd's Avatar
WestCoastTodd
Thanks
Baz.
Are your hubs locked or in 4x4? Bad axle ujoints will do that.
Todd
Old May 17, 2011 | 10:08 AM
SteveH-CO's Avatar
SteveH-CO
If the factory ESOF hub fails to unlock, this noise will happen. Take a pair of snap ring pliers and remove the manual hub bodies on each side and repeat the test (avoid dusty roads). If the clunk is gone, then your problem is caused by a hub that failed to unlock.
If you have manual hubs, just be sure they are unlocked.
Old May 17, 2011 | 01:22 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
And at the same time, you probably have bad, or at least worn, axle shaft joints.
Jfountain86
Aug 5, 2016 12:01 PM
tmyers921
Jun 14, 2016 01:14 PM
erich545
Mar 24, 2016 01:21 AM
kingerbinger
Jun 4, 2015 06:10 AM
7.3lpowerstroke
Oct 22, 2011 01:00 PM
