Sponsored by: Kumho
05 F350 Leveling Kit PROBLEM!
Old Sep 28, 2006 | 11:43 PM
Alaska350's Avatar
Alaska350
All, greetings and salutations. Huge Problem! I put a 2inch leveling kit on my 05 and the passenger side spring keeps hitting the side wall and bump stop mount. Yes it's on correctly, yes the spring is seated properly. I called my buddy at FORD and he said all the 05-06s passenger side spring is only about an inch and a half away from the inside of the fender. On the drivers side its almost 3 inches. So when I lift it, the bar on the front end pulls the the axle to the drivers side in turn putting the passenger side spring closer to the fender wall. ANY TIPS or HELP is appreciated. Thanks, Jimmy
PS the spacers go under the spring mounts.
Old Sep 29, 2006 | 08:33 PM
skirk55's Avatar
skirk55
??? I just put a Ready Lift Leveling Kit on my 2005 F-350 and I did not have that problem. I did have brake lines that were too tight and sway bar linke too tight.
Old Sep 29, 2006 | 08:40 PM
Alaska350's Avatar
Alaska350
SKIRK, how close is your passenger side spring to the inside of the fender well? I couldn't get a finger between the two.
Old Sep 29, 2006 | 09:02 PM
skirk55's Avatar
skirk55
05 F350 leveling kit problem
OK I just went out and looked the springs are the same about 1". Did you mark the spring location and spring? Is the spacer on top" Did you remove the sway bar links? Did you remove the shocks?
Old Sep 30, 2006 | 12:46 PM
Alaska350's Avatar
Alaska350
Yep everything is back in there original places. Went to Ford again today and all the 250's and 350's passenger side springs are closer than the drivers side. WHY is this?
Old Sep 30, 2006 | 04:42 PM
skirk55's Avatar
skirk55
I just looked again and the springs are the same distance. Can you get a photo of this?
Old Oct 1, 2006 | 01:09 PM
Alaska350's Avatar
Alaska350
Shoot me your email address and i'll send the pics. It seems like the entire front end is shifted to the drivers side for some reason.
Old Oct 1, 2006 | 02:06 PM
Alaska350's Avatar
Alaska350
Is it possible that the track bar could be in BACKWARDS, pulling everything to the drivers side?
norvillebob
Jul 23, 2016 08:54 PM
jim4
Feb 15, 2016 09:28 AM
LittleRadio
May 27, 2015 10:52 AM
dan9812
Jan 30, 2013 04:41 PM
minnesotafisherman
47
Oct 4, 2012 01:52 PM
