Soundproofing
I used three rolls of an aluminum roofing adhesive tape... it was essentially 1/16" inch rubber with adhesive on one side, and aluminum layer on the other.
I cut strips and peel 'n stuck it onto the inside of the doors (after removing the plastic panels, of course).
I was surprised that the plastic door panels did not have any sound deadening foam or material. So I bought some carpet padding and hand-cut panels for all six doors. And I stuffed the scraps of padding into the gaps and voids in the panels.
I also disassembled the rear passenger side wall and did the same, except for the panels -- they had sound insulation on them (mine is an extended E-350).
I didn't do the rear driver's side wall because I suspected a certain difficulty in being able to access a majority of the sheetmetal. (The passenger side wall had some cut-outs to reach the sheetmetal, but I wasn't able to reach and cover all the area).
In all, I spent about $85 and six total hours. Do I notice a difference?
Clearly, when you open any of the doors and slam them, there's a "heavy kunk" and a more solid sound -- not exactly a Mercedes, but a whole lot better sounding than stock. !
Driving around town? Yes, there's some improvement. It's not a Lexus, but it's slightly better. Was it worth the time and effort? Probably. Reducing the noise level even a little bit will be appreciated during 12 hour drives when pulling an RV.
Problems? Only with the factory clips. I managed to bust three of them, and one fell inside the door.
It'd be nice if the radio had a noise-canceling feature to help squash road noise... then this van would really be a cross-country cruiser.
Having already done this on three different E250's, all personally owned and daily driven by me so think or believe I have some good ideas.
With the upfitted interiors this isn't really possible however I'm a bit surprised the '05 doesn't seem as quiet as the '02. While I don't like the OEM padded carpeting that should have attenuated a lot of the road noise, padded headliner and sidewall trim panels doing a lot to further reduce road noise.
While its not too practical for Club Wagons etc any sort of partition curtain also cuts a lot of noise out----unless you like isolating passengers from the front seat area, aka limo style?
