blinkers
Old Sep 28, 2006 | 06:43 PM
kjg26's Avatar
kjg26
blinkers
on my way home from work i noticed that my blinkers were being funny. i'd select LEFT and the left blinkers would flash once then very very faintly. same goes for the right side. in the cab the indicator does the same. it blinks once then seems to almost flicker for the rest of the time. help. where should i start.
thanks
keith
Old Sep 28, 2006 | 06:47 PM
xltlariat87's Avatar
xltlariat87
i would say change turn signal flasher. inexpensive part.
Old Sep 28, 2006 | 06:50 PM
xltlariat87
if flasher checks ok. then check grounds.
Old Sep 28, 2006 | 07:17 PM
quicklook2's Avatar
quicklook2
sounds like bad grounds.
Old Sep 28, 2006 | 07:34 PM
kjg26's Avatar
kjg26
were would the flashers be located? it's an 89. also where would the grounds be? talking all chassis/body grounds? or just individual grounds for the blinkers? this happened all of the sudden. they worked fine last night. didn't notice anything this AM on the way to work. just when i started her up this afternoon to head home from work.
Old Sep 28, 2006 | 07:36 PM
kjg26's Avatar
kjg26
also does one flasher control both?
Old Sep 29, 2006 | 06:06 PM
f100beatertruck's Avatar
f100beatertruck
Did you check the blinker fluid?
Sorry, couldn't resist...
Old Sep 29, 2006 | 07:52 PM
kjg26's Avatar
kjg26
ok oddly enough they work today. this leads me to think theres a bad ground. is this a good assumption
Old Oct 1, 2006 | 06:28 PM
kjg26's Avatar
kjg26
it's back. last night it started doing it again
Old Oct 2, 2006 | 11:57 AM
kjg26's Avatar
kjg26
ok its better now. but i think they'll F up again.gunna check the relay sometime this week
rossseger
Nov 3, 2014 02:09 PM
lemasters f100
Feb 15, 2013 12:16 AM
wyckedcombo17
Jul 25, 2011 01:23 PM
diesel77
Apr 26, 2010 08:06 PM
dirtyoldrat
Apr 19, 2009 11:41 AM
