hey guys im back..
my blinkers are messed up now.
heres the deal..
i my blinker cam burnt up.
i tried to fix it and it turns out there are other problems..
i hot wired them and heres the deal.
i can get the fronts the blink left and right side like there supposed to
but the rear break lights both blink at the same time.
and i cant figure them out.
its an odd deal
instead of going through the blinker cam.
i removed it and the peice under it since they were melted.
i just hooked the the blinkers up direct to the wires that hook to the cam.
i have done this before and put them on a to way toggle switch.
The reason it's flashing both rears is the power is backfeeding thru the stop light circuit. The stop lights and turn signals share the same filament in the bulbs. I'd suggest you start by replacing the turn signal switch. If the problem continues then you'll need to start tracing wires.
any idea where a person would find the switch?
all the parts stores around here sale, is the repair kit which is just the cam. thanks for your help...
o yeah by the way, i found the blinker fluide rite next the the new air for tires and the battery fire refill kit.
