how do you shift a ratchet shifter?
Old Sep 27, 2006 | 01:17 PM
81fordf-250's Avatar
81fordf-250
I am buying a ranger with a v8 and an automatic transmission. I would like to know how to idintify the trans with out driving it. It either has an aod or a c4. Also it has a ratchet shifter and i want to know how to shift the darn thing. Nobody has said how to get them into park or reverse all i hear is how to shift them threw the foward gears. I don't really understand how to do that.
Old Sep 27, 2006 | 04:20 PM
460's Avatar
460
This is how mine was...
Just push the shifter forward or pull it back dependeing on what you need to do, then move it back to the "center" position. Repeat the motion to "click" the transmission another gear in that direction.
ex - from park, pull back and return to center to get to reverse. Then pull back and return to center again for nuetral. Then pull back and return to center for ?
I say "?" because there are several types of valve bodies available. Some will put you in regular drive, while other will put you in the top gear or lowest gear. Mine was a full manual reverse pattern valve body and I loved it.
Old Sep 27, 2006 | 05:03 PM
bigdavesohc's Avatar
bigdavesohc
Also, most have a button or lever that you pull to go in and out of park and reverse. Almost like pulling the shift lever toward you in an auto with column shift. You will like a ratchet shifter better than any other auto shifter, they are so much fun!!
Three4all
21
Jan 31, 2012 08:06 AM
Talon302
Aerostar
Sep 19, 2008 11:10 AM
69ford99
1978 - 1996 Big Bronco
Sep 25, 2006 01:07 PM
DRanchero
Feb 11, 2005 11:09 PM
eastcounty_sd
Aug 26, 2004 10:36 AM
