Ratchet Strap Storage
Old Jan 22, 2012 | 01:42 PM
Three4all's Avatar
Three4all
How you all organize or store your ratchet straps? I find it is pain to coil them up every time and always come unraveled...and then they gets kinks and take forever to straighten out. Any almost everyone else I know has the same issue...
I look forward to hearing how other people deal with their ratchet straps clusters...
Old Jan 22, 2012 | 02:58 PM
7.3 Rocket's Avatar
7.3 Rocket
I use 3" straps and I'm quite happy just wrapping the strap around its hook and storing it flat then put the binder in separately.
This allows me to just grab hold of the end of the strap and throw the coil over the load and it lays out perfectly for me every time no fooling around.
Old Jan 22, 2012 | 03:05 PM
jdwoods's Avatar
jdwoods
I do the same, wrap it around the cinch or ratchet mech. and I also store them in a zippered bag under the back seat. so they stay together.
Old Jan 22, 2012 | 04:09 PM
Action4478's Avatar
Action4478
I cut some strips from a small tire inner tube ( like really heavy rubber bands ) & throw each into a wal- mart type bag , then into zippered bag ...
Old Jan 22, 2012 | 05:46 PM
Augster's Avatar
Augster
I roll them up loosely then stuffed them into a 18" soft canvas tool bag (which holds other emergency tools), which I had kept under the passenger seat but now stow it in my BAKBox once I installed that.
Old Jan 23, 2012 | 06:32 AM
JWA's Avatar
JWA
In my work van I carry a number of smaller (1" wide) ratchet straps and Bungee cords, had the same issue with storing them between infrequent use. I bought a small cheap Stanley plastic hinged lid tool box (Lowe's, $10 max) which works out well for me. They're always in the same place, the box is easily stowed and since its dedicated only for this it works out well.
Before putting them into the box I loop them in half, holding the ratchet head and strap hook end in my hand. When the loop is about 2' long I'll put a single knot in the middle which keeps them together and easy to deploy. Its not pretty and/or high tech but it does work!
Old Jan 23, 2012 | 11:47 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
I've only got two ratchet straps (about 3" wide).
To store them, I rolled the straps as tightly as I could, and used a long 'zip tie' to secure each one.
The 'ratchet' is with each strap, in a small plastic container (rubbermaid, I think), with a label on the outside, stored on a shelf in the garage.
I've only used these straps once. . . when we moved a hot-tub.
Old Jan 23, 2012 | 11:59 AM
ArrizX's Avatar
ArrizX
I used mine so often I got tired of rolling them up. I think I find throwing the wad of straps in my tool box and fighting to get them undone is less time consuming than storing them neatly rolled up.
Old Jan 24, 2012 | 08:44 AM
JWA's Avatar
JWA
That was my approach for the longest time too! If I used mine more often that'd probably still be my method. They're easier to carefully pack and use when infrequently used though.
And here I thought I was the only always in a hurry to finish a job............
Old Jan 24, 2012 | 09:37 AM
Talyn's Avatar
Talyn
I usually say screw it and throw it in the box.
But most of them I coil. Easier to throw them when they are coiled.
I leave the ratchet off them when coiled though.
Old Jan 27, 2012 | 11:00 AM
White Max's Avatar
White Max
I coil them up, then use a piece of bailing wire to keep them coiled.
Old Jan 27, 2012 | 12:35 PM
4dfan's Avatar
4dfan
I have about a half a dozen I use for moving fridges with my pickup truck. They're usually wet and rusty from laying in the snow but if I leave them on the floor by the heat they dry right off.
Old Jan 27, 2012 | 09:19 PM
lariat97's Avatar
lariat97
I have mine rolled up & stored in a tool box. I have a small bungee cord around each one.
Old Jan 27, 2012 | 09:30 PM
gddyup's Avatar
gddyup
I typically wrap them up and them stuff them together so they don't unwrap. I just bought an Undercover Swingcase this afternoon for my 08 F250 where I intend to store all those little incidentals like straps and such.
Old Jan 27, 2012 | 10:04 PM
fellro86's Avatar
fellro86
I have two versions, but both I keep the straps rolled up, then store them either in a plastic tool box, or now have soft canvas bag that was intended to hold emergency tire cables which didn't last, but work great for holding the ties. They are velcro sealed.
