Transfer case swap
Old Sep 27, 2006 | 04:20 PM
justintino233's Avatar
justintino233
Transfer case swap
Hi,
I have a 85 F-150 with a 4sp and NP-208. The transfer case slips out of gear going down the road. I picked up another 208 from a C6 Bronco. I am wonderning if this swap can be made...the output shaft on the truck transfer case appears longer than from the Bronco. But everything else at least looks the same.
Any help of if this can be done or what to do about my worn out case would be much appreciated!
Thanks!
Justin
Old Sep 27, 2006 | 06:01 PM
andym's Avatar
andym
The output shafts should be the same. I don't know if this will be an issue, but on newer trucks with the BW13xx case, the Broncos all have fixed yokes, and ther F-series trucks all have slip yokes. Meaning that if you go from one style to the other, you need a new driveshaft that will work between both.
Just something to take a look at.
Old Sep 27, 2006 | 06:50 PM
justintino233
Fixed Yoke on the Bronco XCase
That's what's wierd too, the rear output shaft is fixed on the bronco NP 208. Whereas the rear output on the truck is a slip yoke...
Thanks for your quick reply!
Justin
Old Sep 27, 2006 | 06:54 PM
andym's Avatar
andym
In that case, you either need a Bronco driveshaft that will have to be lengthened by a driveshaft shop, or a different t-case from an F-series.
Gary Lewis
123
Dec 4, 2016 08:10 AM
small.block.ford.guy
Nov 6, 2013 08:34 AM
tnfarmer67
Offroad & 4x4
Apr 15, 2012 09:48 PM
6.9tank
1978 - 1996 Big Bronco
Jul 8, 2004 09:23 AM
Peter Bowler
Aug 11, 2003 05:22 AM
