Diff service
Old Sep 24, 2006 | 07:57 PM
brian931's Avatar
brian931
Diff service
I was thinking of changing the diff fluid in my 99 4x4. I don't want to get too deep so I was thinking of just sucking it out through the fill hole. Will this work and then what kind of fluid do I put back? My ranger does have the limited slip. Is the front diff the same?
Old Sep 24, 2006 | 09:22 PM
Tiggie's Avatar
Tiggie
You can take out the filler plug and suck the fluid out.
It's not that hard to pull the cover off the rear differential. I think you can do it, just seal it back up with some RTV silicone.
I don't have any experince with the front differentials, but you should be able to suck the fluid out through the fill plug opening.
You will need to pick up "Friction Modifier" from the parts store or Ford. I think some types of gear lube they sell now come with the Friction Modifier already in the mix.
You'll want to get 80W-90.
Old Sep 24, 2006 | 11:35 PM
Revolution's Avatar
Revolution
i got a 99 mazda b4000 4x4 and was wondering what kind of diff fluid id need for the rear diff and what geariing is in it and how do i empty it and how do i do the front diff?
thanks
Old Sep 25, 2006 | 10:20 PM
Tiggie's Avatar
Tiggie
thanks
It wouldn't hurt to pick up a Haynes and/or Chilton Manual for the truck. You can get them at most any auto parts store, such as Advance or Auto Zone.
Again, you'll need the 80W-90. If your axle is a limited slip, you'll need the friction modifier to add to the 80W-90. See chart below, look on the sticker in the drivers door jamb under Axle for the code.
(Thanks to RPS for the chart)
Old Sep 26, 2006 | 01:33 AM
Revolution's Avatar
Revolution
according to my axle it is a 96 which is 3.73 which ratio is better 3.73 or a 4.10? how do i know if it is limited slip or not? what else could it be?
Old Sep 26, 2006 | 08:26 PM
Tiggie's Avatar
Tiggie
Axle code 96 would indicate your truck has an 8.8 (standard for 4.0's) rear axle, with 3.73 gears and no limited slip.
3.73 Gears are a good all around gear for the person who wants some acceleration and towing, yet still retaining decent highway mileage.
4.10 gears are great for towing, but not so good for the interstate commute. With 3.73 gears, the driveshaft turns 3.73 times for every one full rotation of the wheel. With 4.10 gears, the driveshaft turns 4.1 times for every one full rotation of the wheel. Thus, the engine RPM is higher with 4.10's at 65mph than 3.73's at 65mph.
Old Sep 26, 2006 | 11:28 PM
bigdavesohc's Avatar
bigdavesohc
...luckily the 5th gear is a little higher to compensate. But not that much higher...
Old Sep 27, 2006 | 01:26 AM
Revolution's Avatar
Revolution
so how could i make it limited slip, would it be worth while going to 4.10 gear?
Old Sep 27, 2006 | 10:22 AM
rubydist's Avatar
rubydist
You would pull out the differential pumpkin and replace it with a l/s pumpkin. This is not for the faint of heart, but isn't extremely difficult. Changing the ratio is the same exercise. (It requires pulling the axles and adjusting gear lash when you install the new gears.) Or, you could find a different axle and swap them. Whether it would be worth it is a personal question - you will see slightly better acceleration, but it will cost you a little in gas mileage. (You will also need to recalibrate the ecu for the different ratio.)
The Ford l/s diffs all specify synthetic fluid, which I believe is 75W140, rather then the 80W90, and do require friction modifiers. The front diffs are all open. If I was changing the fluid, I'd suck it out the plug so I didn't have to mess with sealing up the cover again, but that's just me.
harleyguy27
Jan 21, 2013 12:03 PM
m@m
2004 - 2008 F150
May 23, 2011 03:31 AM
brian931
Apr 8, 2009 07:16 AM
Rich in CO
1997 - 2003 F150
Nov 13, 2006 07:24 PM
rrawlins
Oct 5, 2003 09:00 AM
