front 7 rear diffs leaking?
Old Oct 4, 2003 | 05:37 PM
rrawlins's Avatar
rrawlins
front & rear diffs leaking?
I've was pulling apart my dana 44 front and dana 60 rear to do the brakes. When i pulled the front hubs off, diff oil started leaking out. Same with the rear. When I slid the rear axles out diff fluid started to leak out. I'm thinking that this is not good. The inboard seals are supposed to prevent any diff fluid from leaking out right? What is involved in replacing those inboard seals?
Old Oct 4, 2003 | 05:40 PM
BB's Avatar
BB
I think that's normal, mine leaked when I pulled the rear axles for a brake job. Next time I will put a bucket under it.
Barry
Old Oct 5, 2003 | 08:17 AM
rrawlins's Avatar
rrawlins
So is it normal for the front to weep a bit as well?
Old Oct 5, 2003 | 09:00 AM
willowbilly3's Avatar
willowbilly3
There shouln't be aby connection between the gear section and the outer hub area on the front axle. If you have a closed knuckle front some of the lube from the knickle may have seeped in, there is nothing to prevent that and it is no cause for alarm. I assume you are dealing with an F-250 and if so you have a floating rear axle and the gear lube is what lubes the wheel bearings also, even so never put the bearings in with out prelubing them as it takes a while for any gearlube to get out there from the center.
Steven Stocki
Dec 15, 2016 01:24 PM
bakedkarma
Jul 1, 2016 08:05 PM
WolfCreek540
Jun 9, 2016 01:37 AM
Wrecklesswisdom
35
May 19, 2016 09:52 PM
JNG6
Feb 9, 2016 10:54 PM
