code reader
Old Sep 24, 2006 | 07:00 PM
razor's Avatar
razor
code reader
wanting to get code reader not hi tech tho something reasonably priced for my 99 f-250 7.3 for a shady tree lol love this site all help is appreciated
Old Sep 24, 2006 | 07:04 PM
Sunburnt's Avatar
Sunburnt
From what I have been reading this is the best code reader, unless you what a code reader within a Tuner
http://www.autoenginuity.com/
Old Sep 24, 2006 | 07:28 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Anyone used the OBDII reader from wally world? I eyeballed one tonight, 80-somethin dollars.
Old Sep 24, 2006 | 09:30 PM
jtharvey's Avatar
jtharvey
I"m a big fan of my AE software. More expensive than some code readers, but much, much more capable.
If the code scanner from WM is the same as some of the ones they use at the parts stores, it probably won't work right. There are some codes specific to our trucks that they can't pull.
Old Sep 24, 2006 | 09:37 PM
Uzumati's Avatar
Uzumati
2nd vote for AE with the enhanced ford version you can read any code our trucks can produce. Also you will have a good cross platform odbc diagnostic tool for use with any make once your nieghbors find out you can read codes.
Old Sep 24, 2006 | 09:46 PM
Tenn01PSD350's Avatar
Tenn01PSD350
JT and Alan are correct. It is pricey, but all you have to do is go to the one over world FTE home page to illustrate the point. There is an entire page of 7.3 diesel codes seperate from the standard ford OBDII codes. I don't know if this is because the 7.3 is not OBDII compliant or not but that is the world we live in. So what I am saying is that a standard Ford OBDII code reader will likely not pull all codes, if any from a 7.3. On the other hand, you have the free trial option because Wally takes back just about anything if it does not work. Just a little time on your part.
Old Sep 25, 2006 | 08:37 AM
Pocket's Avatar
Pocket
Ford vehicles have diagnostic codes above and beyond the standard OBDII compliant codes. Same goes for all other manufacturers. A traditional code reader will only read the standard OBDII codes. The problem is that if you have a DTC stored, it's normally a diesel related code, and it won't show up on a normal hand scanner.
Also, if you have a chip installed on your truck, none of the hand scanners will read ANY code, even if it is OBDII. AE is the way to go.
Old Sep 25, 2006 | 08:39 AM
Sunburnt's Avatar
Sunburnt
"one over world FTE home page" ?? Can you give us a link for this, I was unable to find it.
btm991
Dec 15, 2009 07:25 PM
canoe39
May 30, 2007 09:51 PM
KCMAGERS
May 8, 2007 12:36 AM
Quantrex
Sep 2, 2002 06:53 PM
bearbronco
1978 - 1996 Big Bronco
Nov 28, 2001 11:53 AM
