abs light
Old Sep 22, 2006 | 04:41 PM
donald burnash's Avatar
donald burnash
abs light
I have an 03 Excursion w/ an abs problem. Under semi hard acceleration the abs light will come on then go off with no codes. Eventually code c1185 internal power relay will set. All the tests point to the abs module, but after replacement the problem is still there. It does not matter if your driving or setting in park. Help!!!!!!!!!!!!!!!!!!!!!
Epd444
Aug 14, 2013 04:43 PM
boot2
Jun 26, 2012 05:33 PM
bronco5.8
1978 - 1996 Big Bronco
Jun 28, 2005 09:57 AM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
haroutd
Jan 2, 2003 08:19 PM
