2007 Explorer abs problems
Old Jan 11, 2012 | 10:00 PM
boot2's Avatar
boot2
Hope that someone can help. Problem started with ABS light on steady and traction light coming on and off. Had a private shop check the codes and he cleared the codes. Light was out, then came back with the ABS pump running constantly, even with the key off. Had to pull fuse to stop the pump. Code was C1095. Replaced the ABS module. Now the ABS light is blinking and the traction light is on constantly. Codes shown are P1000, B2477, C1095, and B2290.
Any help appreciated.
Old Jan 14, 2012 | 08:13 PM
boot2's Avatar
boot2
Went to the dealership. When the module is replaced, the computer has to be re-configuered. Solved the problem.
Old Jan 15, 2012 | 12:34 PM
shorod's Avatar
shorod
Thank you for following up on what you found the issue to be. I bet that wasn't a cheap fix.
-Rod
Old Jan 17, 2012 | 11:35 PM
boot2's Avatar
boot2
The dealer "gave" me a deal, only charged me a diagnostic fee-$99.95 to reconfigure. Of course the part is $350 plus tax from Ford. Also, have a $150 core charge on the module. I take this to mean that they rebuild them.??
Old Jun 25, 2012 | 09:51 PM
jlf.dmd's Avatar
jlf.dmd
Where is this fuse located that you pulled, the cover does not have a diagram for me to tell what fuse it is.
Old Jun 26, 2012 | 05:33 PM
steve(ill)'s Avatar
steve(ill)
40 amp fuse #5 under the hood drivers side of firewall ??
XbigXredX
Apr 4, 2019 11:44 AM
jhg_12
1978 - 1996 Big Bronco
Apr 22, 2013 03:55 AM
_Me2_
Mar 9, 2013 10:11 PM
86scotty
Sep 23, 2012 11:22 PM
rick4115
Jan 23, 2012 02:46 PM
