speedometer fixing
Old Sep 22, 2006 | 12:24 AM
first6.9's Avatar
first6.9
Unhappy speedometer fixing
My speedometer has quit working on my truck. do these trucks have mech. cables or are they electric. also my fuel guage doesnt seam to read correctly. after fill up it says 1/2 on the front tank and 3/4 on the rear tank. thanks in advance for any help.
Old Sep 22, 2006 | 08:09 AM
dieselbogging's Avatar
dieselbogging
The speedo is run off a cable. The cable runs down to your transfer case and connect to a speed sensor. Either the speed sensor is no good or you have some severd wires for the speed sensor circuit. As for your fuel gage, im not to sure but my best bet is that the fuel pickups in your tanks are on the fritz.
Old Sep 22, 2006 | 08:59 AM
fellro86's Avatar
fellro86
The cable is all there is on an 86, if that's the one you are asking about, no speed sensor, as there is no need for one, being 4 speed, there is no computer to give the info to, so it doesn't have a sensor. The cable may have broken, or the plastic gear in the t-case stripped.
A common problem these senders have is the float filling with fuel. A tiny little pinhole forms where the arm hold the brass float, and the slowly fill up. That would be the guess I would have for why they read, but not up to snuff. Usually, when the sender fails, it reads empty only, or full only. If you get an open spot on the resistor, then it goes to full.
Old Sep 23, 2006 | 12:17 AM
first6.9's Avatar
first6.9
i looked at it today, the cable is there so i am assuming that it is the gear in the t-case. how hard is it to fix that gear. i have built many a t-case before but they have all ben simple t-case's. FTE rules! thank you guys for all your help.
Old Sep 23, 2006 | 01:21 AM
dwaymar's Avatar
dwaymar
simple fix pull old one out and put in new gear find speedo shop in your area and tell them what ya go and they will have one if no spedo shop the autozone hear we come
Old Sep 23, 2006 | 07:40 AM
fellro86's Avatar
fellro86
The cable will often break half way up, so simple visual inspection is not enough. The way to test it is too kook a drill the the end of the cable and see if the speedo mves. Also, the gear inside the t-case may not be the issue, rather the one that goes in with the speedo cable, so you don't have to tear the t-case down, just the gear that you take out. My bet is actually on the cable though. Most times the cable has snapped. It just rarely does it at the end.
Old Sep 23, 2006 | 09:42 AM
Saigon's Avatar
Saigon
The hard part is not at the transfer case end, just one tiny bolt,its getting behind the dash....a real pain, if you have big hands you will need to borrow your girlfiends hand to pull the cable head out of the instrument panel!!!
50trucking
Sep 23, 2014 03:13 PM
orionife
Jan 10, 2008 11:32 PM
firstonraceday
Oct 12, 2005 10:15 AM
RobertNooy
Mar 30, 2003 05:13 PM
