Speedometer / Regearing
Old Mar 30, 2003 | 12:51 AM
RobertNooy's Avatar
RobertNooy
If I were to buy new gears for my truck. Would I be able to buy different speedometer gears so that my speedometer still works.
Old Mar 30, 2003 | 06:19 AM
StrangeRanger's Avatar
StrangeRanger
If you don't tell us what your truck is, no one can answer your questions
Old Mar 30, 2003 | 10:09 AM
RobertNooy's Avatar
RobertNooy
Oh. sorry. Its an '89 F-150 with a 302 and the mazda 5speed. I want a higher gear ratio in the rear end for hauling my toys. ( sled and quad ) thanks
Old Mar 30, 2003 | 11:09 AM
steve83's Avatar
steve83
Yes - Ford sells them for ~$8ea. You'll probably have to do your own math to get the right tooth-counts. Do a few searches - there have been several discussions of it.
Old Mar 30, 2003 | 05:13 PM
RobertNooy's Avatar
RobertNooy
Hey there strange ranger. Well I did a search and I came up with a perfect find. It was a near exact match to my situation. A 1989 f-150 with a mechanical speedo. changing from 3.08 gears to 3.73 with LT235/75R15 tires when the OEM tires were 215/75R15 .I found I will need a 21 tooth driven gear for my speedometer cable because ford does not have a 22 tooth. Judging from your other advice from the links you definitely know your stuff. Keep up the good work and thanks again.
Stevenbowman23
Mar 23, 2015 12:12 AM
purecty
Sep 17, 2011 05:09 AM
DMAN
Oct 28, 2007 09:21 PM
schaad25
Apr 15, 2007 11:03 PM
Yogis1097
Jul 19, 2006 06:38 PM
