which injectors with van turbo??
Old Sep 18, 2006 | 05:54 PM
bigcountry560's Avatar
bigcountry560
ok, so I've just finished swapping everything turbo related from the early to late 99, including a van turbo with ATS housing. There is noticably more lag than before, but not as bad as I thought it would be. My next step is to upgrade the HPOP and injectors which are still early 99 models. I am really struggling on making decisions on what to get. I've thought of just upgrading both to the later 99 model. Just wondering what options you all would reccomend. Also, I have a Predator right now, but I will switch to possibly a DP Tuner if it would be that much more beneficial.
Any help would be appreciated,
thanks
Mike
Old Sep 18, 2006 | 06:21 PM
ron's power stroke's Avatar
ron's power stroke
i cant help you with the inj ??? but i got an early 99 as well.did you get the kit for the swap or did you find the organelle from a late 99 and swap it out? was it a hard swap? how long did it take?thanks alot,
Ron
Old Sep 18, 2006 | 06:43 PM
Pocket's Avatar
Pocket
Once you get a new HPOP and/or injectors, you will NEED a DP-Tuner chip with custom tunes to be able to properly run the new setup.
If you are going all out then go for new injectors and a Terminator or Stealth HPOP setup. Both will supply more oil than any injector out there can possibly use.
Old Sep 18, 2006 | 08:20 PM
bigcountry560
I bought the kit from Dieselsite. It wasn't too bad to do. Lining up the collecter and up-pipes with the turbo was the biggest pain in the butt. I'd plan on a couple days.
I'm not really too concerned about going all out. I just want a combination that works well together without creating other problems. If it takes going all out to get that, then so be it.
thanks
Old Sep 18, 2006 | 08:23 PM
ron's power stroke
thanks for the info. good luck to you and your truck.
Old Sep 19, 2006 | 06:28 PM
lukecline's Avatar
lukecline
stage 2's would be a nice addition to a van turbo
Old Sep 19, 2006 | 06:36 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yep. A stock late pump and some stage two's will do nicely. If you get split shot II's your predator will run them, but there is simply no substitute for custom programming from a performance aspect. If you want to run single shot injectors a custom chip is your only option.
Old Sep 19, 2006 | 06:37 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Stage II splits? Will he have enough oil?
Old Sep 19, 2006 | 08:48 PM
lukecline's Avatar
lukecline
no, stage 2 single shots which would require new programming. Stage 2 single's wont use much if anymore oil than stock AD's, but a late model hpop wont hurt either.
Old Sep 21, 2006 | 04:16 PM
bigcountry560
Thanks for all the input. I've been thinking on the Stage I single shots and upgrade that HPOP to the later 99 style.
Old Sep 21, 2006 | 04:18 PM
bigcountry560
where would the best place be to get the later model HPOP? The only place I"ve seen is Dieselsite
bigbubba87
Aug 23, 2014 10:58 AM
cutlass
Jan 6, 2011 07:47 PM
stemo76
15
Jan 27, 2010 03:08 PM
SuperDutyF250
Oct 25, 2005 10:49 AM
Subdued
Mar 7, 2005 07:24 PM
