Leaking C6
Old May 31, 2001 | 12:14 AM
jowilker's Avatar
jowilker
Leaking C6
Jim, that is a little over kill for a leaking pan isn't it. ;-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old May 31, 2001 | 12:21 AM
Rosati's Avatar
Rosati
Leaking C6
John, you have gotten some good advice from these guys but you may want to do one more thing, run a bottoming tap in each hole to clean the grit out, then spray a couple of shots of brake cleaner in the holes to get rid of the oil, .
Then use a TORQUE WRENCH to tighten the pan bolts to 10-13
ft-lbs. Also, check your bolts. If they have been in and out a few hudred times, they get elongated and the torque reading will be wrong.
Good Luck,
Krosati
Old May 31, 2001 | 12:46 PM
jimarlie's Avatar
jimarlie
Leaking C6
John,
Yeah, it's over kill but a darn good excuse to work on the truck! Have a good ( leak free ) day.
Jim
Old Jun 1, 2001 | 09:26 AM
ole65's Avatar
ole65
Leaking C6
John;
Here are a few things I have learned chasing a leaking C4 pan.Flattening the pan flange is vital, use a sheet of glass to check your work. Clean out those threads in the case with laquer thinner or carb cleaner but also use a round-tail brush to get them clean and dry; same with the bolts. Shellac is a cheap substitute for thread lock. Get a 1/4 inch drive torque wrench and use it rather than tightening by feel. Do everything dry; don't use any sealants or silicon gasket makers.
To drain the converter, disconnect the pump-out line from the trans into a bucket. Start it up, let idle, run it thru the gears to empty the transmission. Then drop the pan, change filter and have fun chasing those pesky leaks. You will succeed!
Lee
1965 F100 short box styleside
Old Jun 1, 2001 | 02:54 PM
jowilker's Avatar
jowilker
Leaking C6
Hey Guys all, thank you for your tips, the fluid is fairly new in the pan and I really didn't want to, but I guess I gotta. I will put it off a little longer but I will do it soon.
With my thanks let's put a ribbon and bow on this thread and end it. :-)
John
jowilker
66F100s Rule
Old Jun 5, 2001 | 09:38 PM
jowilker's Avatar
jowilker
Leaking C6
I stopped in at the tranny shop that built my C6, and asked about Type F & Mercron III and the leaking pan. He said the the fluid was the same, and that because my truck was parked more than driven the fluid drained out of the torque converter back into the pan, raising the level to the dip tube or other areas that normally didn't have fluid there. He suggested that with a flashlight look at all of those areas first for the leaks. He suggested putting teflon tape on the bolts and hopefully the leaking will stop, and if the other seals were leaking he would replace them.
John
jowilker
66F100s Rule
Old Jun 6, 2001 | 05:19 AM
jowilker's Avatar
jowilker
Leaking C6
jowilker
Oct 18, 2008 08:43 PM
jowilker
May 17, 2002 09:01 PM
jowilker
Mar 29, 2002 06:22 AM
jowilker
New York Chapter
18
Mar 25, 2002 09:54 PM
jowilker
25
Feb 20, 2002 08:01 AM
