If you wear glasses you will probably need them. If you look on the front of the block below the drivers side head then you will se a 105 written backwards instead of a 352 which is found on almost all of the blocks before 1973. Also if you look in the spark plug area you will see the D2TE-AA code. Just kidding, I can't see that. That is a nice looking FE John. Good Job! Here is another 1973 - 76 block but the block is about the only thing from that year.
http://www.clubfte.com/users/ratsmoker/Pict0004.JPG
Guys, it's a .040 over 360 now a 390, oil mods done, some porting on the heads for better breathing, also CCed and matched, pistons the same. I just got a Pertronix Igniter and coil today from an Ebay auction. The engine is basically stock, but I think it will haul butt just fine, turning 4500 absolutly max. I have a freshened C6 to go behind it. Thanks for the complements. I hope to have it in the truck by fall
The engine rebuild was done by FTEer Bob Sprowl, with some grunt work from me.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
