Sponsored by: Auxito
Driver's Side Window Issue
Old Sep 16, 2006 | 06:31 PM
brandon_wyer's Avatar
brandon_wyer
I drive a 2002 Ford F150 4x4 and the driver's side window takes longer to go up than the passenger side window. It goes up, but it takes about 10 seconds longer to go up than the passenger side's. Any possible reason why or should I just suck it up and wait the extra 10 seconds?
Old Sep 16, 2006 | 06:43 PM
MZ89's Avatar
MZ89
on my 98, my passenger side goes up noticeably slower than my drivers side.
Havent tried to fix it at all. Either replace the motor, or try greasing everything up maybe?
Old Sep 16, 2006 | 07:07 PM
Gibson13601's Avatar
Gibson13601
My 97 does the same thing on the drivers side..kinda slows right down to an almost stop about halfway up. Motor probally going bad...Ill get to that after I resolve my EGR issues.
Old Sep 17, 2006 | 08:28 PM
jrlowscot's Avatar
jrlowscot
on mine if I spray wd40 down the tracks from above, it lets the window speed up for a month or so. I have tried greasing the tracks behind the door panel. I may try one last time with silicone grease along the vertical tracks
Old Sep 17, 2006 | 10:08 PM
steve(ill)'s Avatar
steve(ill)
it is slow because the window is dragging in the track. the motor is overloading. if you dont fix it the motor will burn up. take off the door panel. rub grease in the slotted track and the wheels running in the track (front to back). spraying the window channel with silicon will help free some things up, but the root cause is probably the motor arm- window steel track and rollers. i sprayed with WD40... did not doo much, then rubbed grease on the slide and z-rails and pins and worked it back and forth. runs 3 times faster now, and lasted for over a year now.
Dpan63
Apr 9, 2014 05:42 AM
Smiggles1970
24
Jan 26, 2013 12:46 PM
SGorman13
Apr 10, 2012 09:34 AM
david49892
1983 - 2012 Ranger & B-Series
Sep 25, 2005 02:25 PM
kable
Electrical Systems/Wiring
Aug 23, 2004 09:44 PM
