Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Trans Flush?
Old Sep 14, 2006 | 06:43 PM
dcuttler500hp's Avatar
dcuttler500hp
Question Trans Flush?
How do I go about flushing my trans. I have a 99' Lightning with 95000 miles on it. I want to put a deeper pan on it and one with a drain plug. What type of fluid is recommended?
Thanks
Don
Last edited by dcuttler500hp; Sep 14, 2006 at 06:51 PM. Reason: Missed spelled word
Old Sep 14, 2006 | 07:09 PM
Blurry94's Avatar
Blurry94
Mercon 5 is what's recommended I believe.
As for flushing, drain the pan, trans cooler, and, if the converter has a drain plug on it, you can drain all of the fluid out of it as well...that'll get just about all of it. You can loosen the bolts on the valve body (and theres a bunch of 'em), but I don't think you'll even get a half a quart out of that.
Old Sep 15, 2006 | 08:31 PM
pronstar's Avatar
pronstar
x2
I prefer this method versus the power-flushing method via a machine.
Old Sep 19, 2006 | 12:39 AM
Stewart_H's Avatar
Stewart_H
Ever since Ford has come out and said to use Mercon 5, going against everything they've said ever since the 4R100 has been manufactured, there's been a lot of naysayers on the Lightning boards as to the validity of Ford's assertion.
The common consensus on the L boards is to continue using the Dextron III/Mercon tranny fluid.
Stewart
Old Oct 31, 2006 | 04:31 PM
blkhd's Avatar
blkhd
Ford allways pushes ford products, my dealer woud not put Mobil 1 in my truck, now i go to Jffy lube, they change to oil and filter with Moble 1 for the same price that I pay at PEP boys just for the oil.
Jake_f16
15
Dec 8, 2012 07:45 AM
country2
Jul 7, 2007 06:34 AM
IAMFORD
Jan 16, 2006 04:47 PM
gbeach
16
Jan 12, 2004 07:57 AM
merkstang
1978 - 1996 Big Bronco
Oct 1, 2003 06:12 AM
