When I did a complete drain including Torque Converter of my '94 E4OD (351 engine) , it was 13-14 Quarts. If you are doing a flushing trick with a cooler line off, I would think you would want more than that amount.
Originally posted by Torky2 When I did a complete drain including Torque Converter of my '94 E4OD (351 engine) , it was 13-14 Quarts. If you are doing a flushing trick with a cooler line off, I would think you would want more than that amount.
Thats the Trick I planned.
Thanks for the info!!!!
