Intake Mod/idea 7.3 Psd
Old Sep 14, 2006 | 02:27 PM
  #31
marvinlong's Avatar
marvinlong
It's basically the same as a tymer
Old Sep 14, 2006 | 02:57 PM
  #32
bigtorque's Avatar
bigtorque
where did you get the pipe.............and does it have the 45 deg. elbow........
Old Sep 14, 2006 | 04:04 PM
  #33
Pocket's Avatar
Pocket
Originally Posted by RAMPAGE_F350
The tube that connects to the turbo is smooth inside, the tube that connects to the filter is not. Which is the tube that the Torque tube replaces.
Mine is smooth, and it's still on my truck. Actually, it's the only original piece of the intake still left under the hood.
Old Sep 14, 2006 | 04:20 PM
  #34
Tenn01PSD350's Avatar
Tenn01PSD350
I see what he is trying to do. I also see the logic in it, but just don't think the ribbed larger pipe hurts it all that much as it has to go through that smaller turbo mounted one. I suppose there would be some turbulence but I don't think it's all that detrimental.
Yes BigTorque, air is a fluid. Turbulence is bad. If the ribs are bugging ya, get an AIS or pipe it. Money better spent.
Old Sep 14, 2006 | 06:39 PM
  #35
bigtorque's Avatar
bigtorque
well, all righty then, picked up a 4in pipe today, going to install it tomorrow, just need to insulate it to keep it cool,,,,hummmmm any ideas????????????
thanks again FTE for all of your info............if this works well, I will take some pics and post.
Old Sep 14, 2006 | 07:14 PM
  #36
Uzumati's Avatar
Uzumati
I was thinking some double walled pipe but I see you already got the pipe. You coulda cut the outer wall back ehuff to get the hose clamps on and that would have given you some dead air space for insulation. Hmmmm how to insulate it and still make it look good????
Old Sep 14, 2006 | 07:28 PM
  #37
white Buffalo's Avatar
white Buffalo
Originally Posted by marvinlong
I use a piece of 4in. exhaust tube for the smoothness. Go for it, buy something for yourself. We deserve it!
I did the same, at least I think this is what you guys are all talking about. I took out that plastic middle piece of the air intake (between the filter & the turbo), the piece that the CCV attaches to. I took it out during the CCV Mod. I haven't had any Higher EGT's from it. Here are a couple of pictures. Is this waht you mean?
Old Sep 14, 2006 | 07:32 PM
  #38
Tenn01PSD350
I believe he wanted the big ribbed portion on the right gone altogether.
You have a setup just like mine, or I have one like yours.
What is that extra clamp and funny looking boot on your hot side pipe? That looks different. Is that stock?
Old Sep 14, 2006 | 07:35 PM
  #39
white Buffalo
OK, so the idea is to cut out the ribbed portion & replace it with another piece of 4" pipe? I'm slow tonight - plus I don't think the German beer is helping much
Fire85
65
Jul 12, 2007 05:37 PM
Tesch101
Jan 14, 2007 09:23 AM
p521us
Jan 10, 2007 01:54 PM
DS02F250
Dec 12, 2006 07:21 PM
