how many pillar gauges, and interior color ?
I'm going to add a pillar pod to add gauges ... I'm planing to put in EGT, boost, and trans temp .. would a 4 pod be a good idea to add air/fuel mix ? Is that useful info ??
Also, my 2001 F250 CC has a "tan" interior .. what's that called ? It's a medium color - I want to have the pod painted to match ..
Tnt right now i am installing a 4 pod piller and the 2 pod bezel that goes over the stock gauge cluster. You can have them painted. my truck interior is grey. I belive your color is called either "Flint" or maybe "parchment"
As far as air fuel I bought the FJO wideband o2 sensor kit. don't know how well it works yet. it was $1000+ If your only gunna spend like 500 or less on a wideband it probibly won't be accurate enough. the fjo i bought has dataloging and rpm pick-up it should prove to be a useful tool
Did you get my snorkel pics? if you respond yes i will mail pictures of all my gauges and bezels.
Ohhh hows the weather in texas? it is 35 here in newengland
74baja
01-17-2009 11:36 AM
