Brakes
Old Sep 11, 2006 | 01:40 PM
SNOWDUTT's Avatar
SNOWDUTT
Brakes
1992 F250. My brake pedal was nearly hitting the floor. After a new master cylinder and new power booster and bleeding, still the same. If I shut the truck off I have plenty of pedal. Help.
Old Sep 11, 2006 | 01:48 PM
andym's Avatar
andym
Did you bench bleed the master cylinder? Did you bleed the ABS valve? In what order did you bleed the rest of the wheels?
Old Sep 11, 2006 | 01:52 PM
SNOWDUTT's Avatar
SNOWDUTT
Bench bled the master, don't know what the ABS valve is. Started with back passenger then back drivers then front passenger and finally front drivers.
Old Sep 11, 2006 | 01:56 PM
andym's Avatar
andym
The ABS valve is on the driver's side framerail about under the master cylinder. You can't miss it, it's got several brake lines going in & out. There is a bleed screw on it. You have the wheel order correct, but you need to bleed the ABS valve before bleeding the wheels.
Old Sep 11, 2006 | 01:59 PM
SNOWDUTT's Avatar
SNOWDUTT
I will try that. Could that cause the pedal to go to the floor only when the engine is running?
AJHEATING
Apr 15, 2022 10:29 AM
nassi
Apr 22, 2014 05:12 PM
stonemason
Jan 18, 2012 11:32 AM
73FOMO
Nov 13, 2005 01:04 PM
