soft brake pedal
Old Jan 18, 2012 | 08:51 AM
stonemason's Avatar
stonemason
soft brake pedal
ok am new here looking for some input with brake pedal i don't loose the pedal .when i use the brakes and the brake lites will come on when the pedal moves about 1.5 inches and seems the brakes are fine no pulling one way ? would it be the vacuum pump i have no issues with driving this way but i know its not right thanks
Old Jan 18, 2012 | 09:11 AM
wycowboy's Avatar
wycowboy
If the vacuum booster is bad usually the brake pedal gets very hard.
I found that all I had to do to firm up my breaks was adjust the rear drum breaks.
This is simple to do .. About a 10 mim job. An indication that this might be the problem as well is if you have to really smash the parking break to get it to hold.
Old Jan 18, 2012 | 09:35 AM
stonemason's Avatar
stonemason
now that i think of if the parking brake not hook up i just got this trurk so this is only one of the issuse i have with it 95 ccb 4x4 psb 19000 thanks
Old Jan 18, 2012 | 09:47 AM
j250hd's Avatar
j250hd
Would rear axle seals that ate leaking cause this as well? I'm having the same problem!
Old Jan 18, 2012 | 10:17 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
First of all WELCOME a board.
Yes when the vacuum pump fails the brake gets hard. Also agree with the rear adjusment brakes. Other thing check the brake fluid level in the reservoir and maybe need to purge of the system.
Old Jan 18, 2012 | 11:32 AM
stonemason's Avatar
stonemason
thanks this site has help me a lot with the problems with owning a 17 yr old psp
Bluesaber
Jan 19, 2012 04:58 PM
1978fordf250
Feb 1, 2008 04:47 PM
steve1147
Jan 19, 2004 09:28 PM
Torstein
Apr 27, 2003 04:20 PM
