smog pump question
Old Sep 9, 2006 | 04:41 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
smog pump question
just tossing around an idea here....on my 89 listed in my sig i have removed the cats and disabled the egr, smog is not a problem....I hate how the pcv system sucks all the oil vapor into my inake and causes the buildup on everything, i have already made a crackcase breather that doesnt soak my air filter with oil like the stock element
i was thinking instead of running the pcv into the intake....run it into the intake of the smog pump and let the pump push the crankcase vapors into the exhaust.... that way there is still negative pressure in the crankcase, but im not pulling the vapors through the motor, similar to the systems used on alot of race engines...
anyone see any problem with this? think the smog pump would move too much air and i woudl have problems with gaskets sucking in??
just a thought since my smog pump is now doing nothing but pumping air into the atmosphere
Old Sep 9, 2006 | 06:25 AM
frederic's Avatar
frederic
oil mist/vapor does burn....
Old Sep 9, 2006 | 02:20 PM
KubotaOrange76
yes, but it also coats the inside of my intake and the sensors in the intake before it burns,
Old Sep 11, 2006 | 06:43 AM
Scndsin's Avatar
Scndsin
Steeda has a neat little oil seperator that they developed for modular mustangs and list as being adaptable to just about any gas burner that uses a pvc valve. Sounds as if it would be just the ticket.
Old Sep 11, 2006 | 12:50 PM
puck1263's Avatar
puck1263
I'd check for proper PCV valve operation before I did anything. HOwever, if you intend to do something, lets borrow an idea from the cooling system. I suggest gettting an empty bottle from a quart of oil and mounting it (via cable ties, etc.) next to your air filter box. Re-route your PCV breather to it instead of the air filter box. Use the bottle as a collection vessel and drill a small hole in it to vent. That would solve your problem as long as you remember to check the bottle and empty it now and then. It's a little rednect, but better than expelling it to the ground.
Old Sep 11, 2006 | 02:45 PM
frederic's Avatar
frederic
Then you have a clog somewhere. Oil vapor is all that is supposed to go into the intake, not quart after quart nor chucks of crispy oily matter.
I'd start by checking the PCV valve and go from there.
Old Sep 12, 2006 | 10:56 PM
KubotaOrange76
nothing wrong with my pcv system, oil vapor is all tht goes into my intke, but i would rather it not go through my motor, it coats the intake air temp sensor and messes up the reading, its not near as bad now that i disabled the egr, this motor uses nor leaks any oil in 3k miles
i just wanted an opinion on how you all think the smog pump would do as far as keeping the crankcase under negative pressure, think it would be too much or too little?
Old Apr 15, 2019 | 10:15 PM
KubotaOrange76
This thing had a bunch of blowby. I think a ring stuck as it started using 1 qt in 900 miles.
The pcv couldnt keep up, so i hooked it to the smog pump intake. Worked awesome and dumped it into the exhaust.
until the smog pump gave up the ghost and started squealing after a few weeks so i gutted it. Went to a dual pcv system��
later on i got the rings un stuck and oil consumption and excessive blowby stopped
Old Apr 16, 2019 | 02:25 AM
frank5079's Avatar
frank5079
Talking
Blow by is what killed my old 300 six; mine started out initially like your problem and then later progressed as oil leaks. I started by replacing gaskets....first the bottom side cover gasket, then the top valve cover gasket. Then oil started seeping out of the air box, and then started pushing through my head gasket and mixing with my coolant. The final death knell was my PCV popping off. I was going to replace it with a straight hose connection, but the blow by through the PCV grommet ignited from a small exhaust crack in the rear of my exhaust manifold, resulting in a small fire that burned part of my rear engine harness as well as part of the fuel rail. The bright side to this was that I wanted to do a V8 swap anyway so the rest is history....I definitely love my 351 swap....
Old Apr 16, 2019 | 07:00 AM
KubotaOrange76
How many miles were on your 6 when that happened?
Old Apr 16, 2019 | 08:03 AM
ZombieF150's Avatar
ZombieF150
oil catch can.
They are cheap on ebay or amazon. I installed one on my 300 I6 because of the gunk after 20+ years inside the intake. The hose routes from PCV to catch can then from catch can to intake.
Oil and water vapor stay in the can. I only have to empty mine once an oil change.
hooler1
Apr 16, 2011 11:00 PM
4rdnut
Dec 22, 2010 03:28 PM
Daddyo's garage
Aug 18, 2010 06:33 AM
SmokyOlFord
Jul 14, 2005 06:31 PM
DailyDriver
Oil & Lubrication
May 10, 2002 11:01 PM
