7K RPM Flathead?
Old Sep 8, 2006 | 09:13 PM
WillyB's Avatar
WillyB
7K RPM Flathead?
My friend Phil H has emailed me some more about his 1950's racer - he said, "I was able to run the engine at around 7000 RPM, partly due to the fact that it was on 60 percent nitro which only needed about 2 parts of air to 1 part of fuel. That pretty well handles the old theory that a flathead can't breath above 5500."
Anybody else have any experance with high RPM flatheads?
Old Sep 8, 2006 | 11:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I wouldn't want to be around any 3-main-bearing engine turning 7k
It really doesn't prove that a flathead can breath, since he was skirting the problem by pumping oxygenated fuel in.
Old Sep 8, 2006 | 11:33 PM
Fomoko1's Avatar
Fomoko1
Still a neat feat when you think about an old Flattie spining that fast.
Old Sep 8, 2006 | 11:38 PM
bob s jr's Avatar
bob s jr
kens and leslie had one years ago but they fabed a girdle to hold the crank offy 4 duec set and overhead valve conversion they had it on display at the shop just before they closed up the shop bout ten years ago.
Old Sep 9, 2006 | 12:38 AM
TheSovereign53's Avatar
TheSovereign53
That would be quite scary indeed. Scary as in doing timing on a Porsche. Sticking your hands right next to big sucking blades at 6k rpms. Eek.
Old Sep 9, 2006 | 12:48 AM
bob s jr's Avatar
bob s jr
they ran it once from what my dad told me the put it i an altered and first trip was running about 140 at 3/4 th the way thruog the quarter and lost it and hit the wall .the guy scrapped the car and sold the engine back to them.
Old Sep 9, 2006 | 05:48 AM
4tl8ford's Avatar
4tl8ford
At 7K I suspect that was just a bunch of holes waiting to appear.
Old Sep 10, 2006 | 01:54 AM
WillyB's Avatar
WillyB
He used that same engine for 4 years - but it was circle track racing so no telling how often he rapped it tight. I understand that Barney Navarro also ran a 180 flatcrank on nitro, I think that '27 is in the NHRA Museum in Pomona. Maybe one of the socal brothers can confirm that.
I don't think there was much stock left in the engine - they ran different cranks, cams, pistons, and rods. The valves were oversized, and the firing order changed to keep the center cylinders from interfering with each other.
Old Sep 10, 2006 | 01:42 PM
bob s jr's Avatar
bob s jr
in the 80 there a 34 hiboy with a 671 blown flat head covered by hot rod that set a buch of records at datona speedway back in the day they had hop up parts for those old flat heads as ***** b mentioned. there was many records set with those old flat heads that wasnt beat until the 70s and 80s but the flat went away becace the modern v8 became alot cheaper to hop up and more avalible.
51phil
Sep 16, 2011 04:11 PM
51phil
May 30, 2011 06:31 PM
cpt.phil
Nov 6, 2009 01:53 PM
abe
Apr 9, 2009 04:13 AM
snipa
Sep 7, 2005 02:25 PM
