Transfercase shift motor
Old Sep 5, 2006 | 01:27 PM
Jimmygunz3's Avatar
Jimmygunz3
I think my transfer case shift motor is sticking on my 99 eb expo, has anyone tried to take the motor apart and see why is sometimes get stuck? when i pull it off am curious to see why they keep gettin stuck. and also when the shift motor is replaced does the battery have to be disconnected to reset the GEM...........
Old Sep 6, 2006 | 02:19 AM
Freak4Ford's Avatar
Freak4Ford
Have you tried changing your transfer case fluid first?
Old Sep 6, 2006 | 09:12 AM
Jimmygunz3's Avatar
Jimmygunz3
What does the fluid have to do with the shift motor sticking and not working? These motors are known for getting stuck..
Old Sep 6, 2006 | 10:00 AM
dkoenig's Avatar
dkoenig
Um.... Why do you think the (lubricating) fluid is there? Have you changed the fluids?
Old Sep 6, 2006 | 12:11 PM
Jimmygunz3's Avatar
Jimmygunz3
yes the fluid was changed, the motor is mounted on the outside of the transfercase and has nothing to do with the fluid.
Old Sep 6, 2006 | 01:29 PM
Jimmygunz3's Avatar
Jimmygunz3
THIS IS WHAT I WAS LOOKING FOR:
Originally Posted by dallas lewis
Thanks for the help grey. I finally got it to work. I decided to take the motor apart and put it back together again. I don't have the slightest clue what I did differently, except for the fact that I made sure the armature inside the motor spun freely before I put it all back together. I put it back on the transfer case and it worked just like it should.
BTW- Someone should write up a post about how easy it is to clean these shift motors. There really is NOTHING to it. Even an amateur could do it. And as for the three wires that go into the transfer case(sensor IDs and magnetic clutch feed), everyone should know that they DON'T have to be cut and spliced. There is a red lock(a plastic piece around the center pin) in the connector that can be pulled out with a pick of some kind that will allow the pins to be released with a screwdriver. But anyway, thanks again.
ALSO I WAS TOLD THAT THE REASON THE MOTOR STOPS WORKING IS FROM LACK OF USE , THERE ARE METAL CONTACT THAT CET DIRTY AND ONCE A MONTH THE MOTOR SHOULD BE PUT IN 4WD TO KEEP THE CONYACTS CLEAN
Old Sep 6, 2006 | 01:57 PM
dkoenig's Avatar
dkoenig
Ah. Good to know. Thank you for posting the relevent point to the solution as well.
Old Feb 12, 2007 | 03:03 PM
DougByrd's Avatar
DougByrd
so has someone written a write up on cleaing the motor?
Mine is siezed up. the car thinks it is in 4lo but it is in fact, in 2wd. and the transmission is going in to protected mode or whatever and the cruise light blinks when shifting into third gear
Old Mar 31, 2007 | 04:50 PM
jdaniels's Avatar
jdaniels
Hope this helps.. here is a link to a rebuild procedure.. https://www.ford-trucks.com/forums/s....php?p=1102904 im sure it would apply to all shift motors....
Old Mar 31, 2007 | 04:57 PM
renouard21's Avatar
renouard21
This is my first posting and am hoping that someone can help. I have a 2002 diesel excursion. Once last week as I parked and locked the truck with the key fob, the alarm went off. after some fideling, open close doors, start ignition, close and open doors again, lock and unlock, etc, aftrer about 5 moinutes I got it to stop, not sure exactly how.
Then last night as I returned home it happened again this time just when I closed the door, but did not lock it. Nothing I did could shut it off till I removed both battery cables.
Any Ideas?
BadBee
13
Sep 23, 2016 08:59 PM
underdogl3
Feb 18, 2016 07:00 PM
Early 1969
Oct 11, 2013 04:37 PM
TGSTP
1997 - 2003 F150
Mar 6, 2011 11:48 AM
matty169
Jan 8, 2008 12:59 PM
