Help!!! 2000 Expy stuck in 4WD!!
Old Sep 11, 2016 | 06:58 PM
BadBee's Avatar
BadBee
Hello All,
I've reading a couple of other posts BUT!!! My 2000 Expy is stuck in 4WD, the interior selector switch light goes on when I switch from AWD to 4H,4L, I can hear the shift motor engaging but I'm getting a banging noise in the front axles?
I have removed fuse #104 and still no results, front is still engaged, there is no
Actuator on front axle, I have the box behind the battery and two lines one going to each front axle,my plan was to remove front shaft and see if front still binds when turning? Could it be bad CV joints? Or the actuator on the wheels themselves? Shift motor on transfer case stuck?? Any input APPRECIATED!!!
A THANK YOU IN ADVANCE!!!!
Mitch
Old Sep 11, 2016 | 07:48 PM
pdqford's Avatar
pdqford
Originally Posted by BadBee
there is no
You might want to double check that - I don't believe that a 2000 Expy has a front axle actuator OR IWEs.
And pulling fuse 104 will kill power to the transfer case shift relays, preventing the transfer case shift motor from functioning.
I'm assuming that the transfer case shift motor is functioning since you stated that it shifted from high range to low range. Might want to verify that the "low2high" transfer case shift relay (up at the top center of the I/P) is getting power and is sending power to the TC shift motor. .
Old Sep 11, 2016 | 08:11 PM
BadBee's Avatar
BadBee
Hi Jim,
Thanks for the input! The I/P is located where? Yes you are correct there is no actuator on the front axle,so it's just the two lines going out of the box behind the battery to each wheel,is it possible for those actuator within the wheel to fail? I tried a vacuum pump on them while disconnected and they hold pressure no problem. The AWD switch seems fine from AWD to 4WH to 4WL and back but front WILL NOT DISENGAGE!! Shift motor seems to click from all selections!!
Thanks,
Mitch
ExplorerTominCO's Avatar
ExplorerTominCO
Yes- put the fuse back in.
Old Sep 11, 2016 | 09:12 PM
pdqford's Avatar
pdqford
I/P = Instrument Panel, or maybe better yet, dash board?
Old Sep 11, 2016 | 09:19 PM
pdqford's Avatar
pdqford
And there are no lines going out to each wheel. The front wheels/hubs/axle shafts/Diff/front driveshaft are all permanently connected to each other.
Check for power at the low2high solenoid and at the TC shift motor.
Old Sep 12, 2016 | 10:04 AM
alloro's Avatar
alloro
If pulling out fuse 104 didn't clear up the issue then the problem is a mechanical failure of the forward clutch inside the transfer case. The vehicle will be drivable and feel normal if you remove the front driveshaft.
Old Sep 12, 2016 | 11:48 AM
BadBee's Avatar
BadBee
Thanks Alloro!!
I did pull the box behind the battery with one line connected to it,when I removed the line the air released, is the box good? Or does it have a relief valve in it? Any way of testing it?
Or am I good to go and use this box till clutch is repaired in transfer case??
A MANY THANKS TO ALL!!!
GOD BLESS AMERICA AND OUR VETERANS!!!
Mitch
Old Sep 12, 2016 | 12:23 PM
pdqford's Avatar
pdqford
Yep. Its good.
Its for your HVAC controls.
(Look where those vacuum lines go. You DO NOT have IWEs.)
Old Sep 12, 2016 | 01:20 PM
BadBee's Avatar
BadBee
Thanks PDQ!!
What are the two vacuum lines going into the back of the two front wheels???
Thanks in ADVANCE!!
Old Sep 12, 2016 | 04:35 PM
pdqford's Avatar
pdqford
IDK. Are you sure they are vacuum lines?
Maybe your looking at the ABS wheel speed sensors.
Or maybe you have modified your Expy?
Do you do pictures?
Old Sep 12, 2016 | 08:31 PM
BadBee's Avatar
BadBee
Thanks Alloro and you also Jimmy(PDQ)!!!
I took out front shaft this afternoon and made a 70 mile round trip working my bird dogs,
Front wheels disengaged (F-TROOP BACK TO NORMAL!!) how ever back to forward clutch/transfer case issue- ??? I have knowledge to drop tranny x case but no facility to do so, so at 58 I'll sub out the job, what is a reasonable price to repair forward clutch in transfer case?? I'm a ford truck guy with 5-F250's 4broncos and 2 expys with 4.6s I love em!!!
Thanks for all the help and INPUT!!!
Mitch
Old Sep 23, 2016 | 06:27 PM
BadBee's Avatar
BadBee
End result!!!!
Thanks Alloro,PDQ!!!
I got a donor vehicle swapped out TC and F TROOP Back to NORMAL!!!
Mist have been clutch pack,when I have time I'll break old one down and check it out!!
THANKS TO ALL!!
Old Sep 23, 2016 | 08:59 PM
pdqford's Avatar
pdqford
Thanks for reporting back the resolution.
powerram50
13
Mar 15, 2017 07:10 PM
Emithez
Feb 18, 2017 12:19 PM
SHADOWDUDE
Nov 13, 2011 09:28 AM
boatcop1
Jul 8, 2005 09:29 AM
